Hi guy's i am pretty much at wits end, it will not start, originally it turned over with original key but through EXTENSIVE recearch i found that the BCM was corroded beyond repair. so i have replaced it with a compatable unit , my mechanic mate said all is good BUT now i do not have any ignition lights so no power is getting to the computer. my question is why don't i have any ignition when i had it before? How do i get this car to run. any advise is welcome
have you got the matching key head from the new bcm you put in
could even be the bcm fuse if no powers getting to the ecu
Did you change the BCM while the battery was still conected? you may have blown a fuse somewhere.
Hi guy,s yes i had a blown fuse but looked intact i should have known. And yes i have it running the problem was that the fuel relay was not sending a proper volatge to the pump so i bridged the terminals with the relay out and it started then i replaced the relay and so it goes. Thanks
