i got a prob with me 94 vr 5L caprice stateman i was driveing and she dyed in tha ars she coffs splaters i go 2 put in drive and put my foot down she dyes in tha ars a again mate so i replace the coil she coffs and splatters still so bort spark plug leads i put them on it dose the sames oh im looking 4 dyegram 4 the fireing order
English please, OK.....
Now, this might be stiupid but there are 3 basic things a motor needs Fuel/Spark/Air... so...
1st - Does it have fuel in the tank?
yes and got spark
and the fuelpump works 2 i checked that
possible hall efeect snsor or igniton module
Originally Posted by Smidy
hall efeect ? whots that mate
try changing your tps sensor mate. its the sensor that is connected to underneath your throttle body that senses how open or closed the butterfly is. should be able to get one from a wreckers for like 5 or 10 bucks. if that doesnt work try your map sensor (the small black box attached to the firewall near your throttle body) and also check out the hose from the map sensor to the throttle body for damage, that can cause similar problems too. good luck mate
hall effect sensor is the one in the distributor, check ya earth leads too my vs wouldn't start then later started but ran like crap due to a dodgy earth lead.
holden V8 firing order is 12784563. from the drivers side front cylinder working back to the firewall they are 1-3-5-7. passenger side is 2-4-6-8
I GOT SPARK and feul as i sead put new coil an spark plug leads its wineing over but knot kicking over dam
wait so the car is not starting at all? in your first post you didnt say that. you really gotta re-word your first post into the english language so we can properly help you
yes 1st post i did say it was running but since then i have chnaged the coil and got new leads the only thing is now the leads may be on wrong so ive got a mate to put them on and now what its doing is it just winds over but wont kick over
ive got the timing on top end dead centre with the rotor button facing towards 1 on the dizzy cap
haul effects had the same problem put a new dizzy in
i put the shop 2 get fixed i was stumped lol
