Results 1 to 7 of 7
Thread: Programming Stock VS Calais Stereo
    VS Calais
    Jul 2010
    Australia
    Default Programming Stock VS Calais Stereo
    I was just wondering if anyone knows how to put the pin code in the stock factory stereo in a Calais. I've had trouble with this even though I have the correct pin. I have taken it to a dealer before but would like to know how to program it myself.
    Thanks
    VS Calais S1
    Jul 2006
    Kadina, SA
    Should just be a matter of typing the pin in using the numbers. At least thats how I remember it being when I had the stock headunit. Also from memory if you use a bunch of zero's it will put it into test mode or something and work for about a minute or so.
    vs commodore
    Oct 2009
    Tamworth NSW
    The VS gregorys workshop book says this:The number 1 will show up in the window with the ignition key in the on position to show how many tries are left..Enter the security code by pressing the numbered preset buttons.If the correct security code is entered,the system will function after 5 seconds.If the security code is wrong,you get 2 more tries at entering it,if its incorrectly entered 3 times,you will have to wait an hour with the unit powered up,before you can try again.
    VS Calais
    Jul 2010
    Australia
    Thanks everyone for your help. I tried to go by the instruction manual but have had no luck. So I'll enter the first digit and then nothing happens then when I enter the second digit it just adds to the last digit typed - not sure if this makes sense the way I've described it but no success so far.
    vs calais
    Dec 2008
    i think its 6 digits
    you just enter them in order via the buttons (dont worry about what the display says)
    after you enter the 6th digit the unit pauses for a second and turns on
    see how you go
    VS Calais
    Jul 2010
    Australia
    Thanks admir87, I finally programmed it. Thanks for your advice. Much appreciated!
    vs commodore
    Oct 2009
    Tamworth NSW
    The security code for my original VS stereo is only a 4 digit number,which works fine.Ive used it a few times now.The tech 1 scantool on the other hand ,shows it as being a 6 digit number though.Theres two zeros in front of the actual code.Ive never had to enter these two zeros before,just the 4 digits.Hmm.
  1. Modifying a VX Stock Stereo.
    By Mick1988 in forum Electrical Wiring / Questions
    Last Post: 14-10-2009, 09:22 PM
  2. can someone help me?! (sub/stock stereo)
    By mitch-vt in forum Car Audio
    Last Post: 18-09-2009, 04:12 PM
  3. Anyone else not satisfied with the Calais stock stereo?
    By JBDrifter in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2008, 08:35 PM
  4. Stock stereo
    By caldonia in forum Car Audio
    Last Post: 09-04-2007, 10:04 AM
  5. VK Calais stock auto to stock 6 cylinder manual.
    By TheKnightTemplar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-07-2005, 08:01 PM
