Results 1 to 9 of 9
Thread: Brake Rotors for sale online, will they fit?
    VR SS
    May 2009
    Wellington, New Zealand
    Default Brake Rotors for sale online, will they fit?
    I have a VR SS, and don't know if the front rotors are different to a standard VR. This looks like a good deal, but don't want to buy them without being sure they'll fit.
    Holden Front Hub/Rotor Brake Discs VR/VS for sale - TradeMe.co.nz - New Zealand
    They gave me this Repco part number: 9946109 Hub & Disc.
    Any ideas, or not enough info to go on?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    SS rotors should be the same bud, someone might correct me if I'm wrong but I'm fairly sure all factory holdens had the same brakes from about VC to VS.
    VR SS
    May 2009
    Thanks! I'd like to go bigger and better but it looks like the kits are pretty expensive. This will keep me out of trouble for a while...
    Is it just me or did they fit the smallest brakes possible on my Holden?
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Quote Originally Posted by soop View Post
    Nah earlier models got bigger brakes on V8s and HSVs and stuff.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    The standard brakes on Commodores have never been great until the VT went twin piston etc
    The brakes on my mates Hyundai Accent are better then mine.
    NA 3.8 VS Ute
    Sep 2009
    No fixed address, Auckland, NZ
    In my experience - VP and earlier, the disc is part of the hub. Where VR-VS discs are a hat over hub arrangement measuring 286mm diameter x 24mm thick with single piston calipers, V6 & V8 discs are the same except HSV are larger diameter 328mm?.
    The VT discs measure 296mm x 28mm thick with 2 spot calipers. These will fit VR-VS with spacers for hubs, as VT hubs use a slightly larger wheel bore. Alternatively use VT Hubs and it bolts on. Chassis end of brake hoses are different though, requiring aftermarket ones.
    I'm about to fit Slotted VT discs with Nissan 4 pot calipers using custom brackets.. Hoses & Hubs/Hub spacers Umm
    "Life's a dare, push yourself, F#@k it you might like it. Live on the edge. It could all stop tomorrow"
    - Jimmy Barnes twitter March 2011
    3.8T Wagon
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    I Found the brake setups different from VN though to the VS. Might want to double check. Hell i cant even remember now, I Know the VX has the same set up as the VY SS lol
    Nov 2008
    Smithton, Tasmania.
    What I mean is the calipers are the same (think) the rotors and hubs changed a few times.
    But if those rotors are for the VS, then they will fit.
    Frankly the calipers don't look a great deal different to the brakes off the Torana's and HQ's .
    VR SS
    May 2009
    Thanks for all the help guys. It turns out I have enough brakes left that I don't need to do it for a few months. I'll keep working on other problems in the meantime.
  1. New brake rotors
    By myberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2008, 08:40 AM
  2. brake rotors.
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2008, 10:02 PM
  3. brake rotors
    By veclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 11:08 AM
  4. VT Brake Rotors
    By Trevor 062 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2005, 12:47 PM
  5. Vn Brake Rotors
    By patto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2004, 12:54 PM
