Results 1 to 2 of 2
Thread: Vr ignition
    vn ute
    Jul 2010
    adelaide
    Default Vr ignition
    Hello everyone, I have a slight problem im hoping to get some help with. When I put my key into ignition there is alot of play there but the key will not turn. I think you need to have the ignition turned on to be able to remove the barrell. What should I do somehow break the barrell of or could i call in a locksmith to fix the barrell
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    ok so the key wont turn at all,, sounds like the barrel has collapsed. have you tried to tap it in with a hammer? if you can get it to push in you should be able to turn it to accessories witch is were it needs to be so you can release the old barrel an fit the new one
    Signature Goes Here
LinkBacks (?)
  1. 27-09-2011, 07:17 PM
  1. vr ignition
    By customvlcommy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2010, 10:51 AM
  2. No Ignition Spark from ignition coil?????
    By Huddo001 in forum V8 Development and Modification
    Last Post: 14-04-2010, 06:54 AM
  3. ignition on my car
    By SV62NV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2009, 09:09 PM
  4. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  5. ignition key
    By wayne burge in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2006, 12:35 AM
