Results 1 to 6 of 6
Thread: Power Steering Fluid Leak
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Default Power Steering Fluid Leak
    Hey guys.
    Check out the photos and I'll try to describe what is happening. The photos are of the top-right side of the steering rack on my VR, where the steering shaft connects to the rack.
    As you can see, the area is covered in PS fluid and appears to be leaking from under that red rubber (seal?). I'm not sure if it is meant to be a seal because it is just loosely sitting there.
    Any idea how to fix this leak?
    Attached Thumbnails Attached Thumbnails Power Steering Fluid Leak-dsc00075.jpg   Power Steering Fluid Leak-dsc00076.jpg
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    If your fluid is not rushing out, like seeing it all over the driveway, and just looses a little over 6 months can continue to drive it like that, or as soop said new steering rack. My VR level drops every 6 months, just a little top up and still good :-)
    VS Stato SII L67 S/C V6
    Apr 2004
    They pretty much all leak. Keep driving it until it starts urinating out or the thing dies, then swap it with a reco rack.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd try some power steering stop leak first - costs less than $14 and does work. I've used it in many cars...may take a fortnight or so to slow things down but can save you a lot of $$$$. I prefer to use Nulon brand which works good for me. Alternative is a reco rack at about $300 plus the hassle of fitting it.
    Mar 2006
    NZ
    Thanks for everyone's responses.
    Forgot to mention I put some stop leak in it about a week ago. It's not gushing out, I just have to top up every so often. The only reason I wanted to fix it was because it failed a Warrant of Fitness (NZ) on it. I think I'll just clean it up a bit and take it somewhere else (it's not as if it's unsafe). If anyone in the Auckland region knows where to get a dodgy WOF a PM would be appreciated. ;-)
  1. VT 98 power steering fluid leak
    By sachin.sachdeva2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2009, 12:44 PM
  2. power steering fluid leak
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2009, 03:00 PM
  3. Power steering fluid leak
    By Tuttle in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-06-2009, 06:43 PM
  4. Power steering Fluid leak
    By 410ci in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2009, 02:53 PM
  5. VN power steering fluid leak
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2006, 11:23 PM
