Results 1 to 9 of 9
Thread: Few question about VS rear brakes...
    96 VS Acclaim
    Mar 2010
    Default Few question about VS rear brakes...
    Hey folks. I got a 1996 VS commodore acclaim series 1. It's got abs and all the safety features and what not, but do I have IRS?
    I need to change my rear calipers and pads and I don't feel like paying $600 to a mechanic to do it.
    How hard is this task? I have changed a lot of parts on this commodore but these brakes need to be done ASAP.
    vs commodore
    Oct 2009
    Tamworth NSW
    Buy a VS gregorys workshop manual if you are gonna do your own work.Its a lot cheaper than paying a mechanic,they have heaps of pics,and is all written step by step, you cant go wrong,and you will know its done right.It will show you how to change the brake pads and heaps more.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Why do your rear calipers need to be changed?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    96 VS Acclaim
    Mar 2010
    I have a haynes manual and I just find it too broad and hard to relate into my car. I haven't checked out the brake section though so I'll give it a go brett.
    My rear calipers need to be changed because metal was rubbing on metal and they're farked.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Quote Originally Posted by deXtrous View Post
    Hey folks. I got a 1996 VS commodore acclaim series 1. It's got abs and all the safety features and what not, but do I have IRS?.
    Search is your friend...Live Axel or IRS on S-Packs?
    Or... Left is IRS, right is solid/live axel.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Go to a wrecker, pull off some rear calipers. Take them home, attack them with a wire brush (attached to a power drill) and then paint them and throw them on your car with new pads and rotors
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VP Exec
    Jun 2005
    Do you mean discs - the parts that rotate with the wheels?
    Quote Originally Posted by IBLOWN View Post
    Im certain all Acclaims came standard with IRS.
    Yep. VR included.
    If you are changing discs, you will need to adjust the park brake shoes inside the new discs.
    If it is the calipers, you will have to bleed the hydraulic system.
    Otherwise it's very straightforward.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Metal rubbing on metal will be the backing pad rubbing on the rotors. You will need new rotors and pad but it's unlikely that you will need new calipers unless the friction heat has damaged the caliper seals.
  1. Rear Brakes Question
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2009, 02:02 AM
  2. ANOTHER brakes question
    By Leebo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-05-2009, 06:17 PM
  3. Using Harrop Adapter to fit VT-VY rear brakes to VL-VS solid rear axle
    By Surfwagon in forum Holden Commodore How-To's
    Last Post: 26-11-2007, 04:46 PM
  4. HSV brakes question
    By EXCESSV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2006, 07:15 PM
