Results 1 to 8 of 8
Thread: How to change power steering hoses
    VS Caprice SII
    Mar 2007
    Northern Suburbs
    Default How to change power steering hoses
    hey guys i am wondering how is the best way to change the power steering hoses as they are starting to deteriorate badly. i also wanna put in some fresh fluid. how do i do this without getting any air in the system. any help would be apppreciated thanks!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    which hoses do you mean - the ones from the reservoir to the pump or the ones from the pump to the rack?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    The rubber hoses are simple just undo the clamps and replace with new hoses and new clamps if needed and do up well.
    The high pressure metal hoses can be real buggers, you WILL need the correct size pipe spanners to get them off, then replace them along with new O rings. Dont worry about air in the system, once you refill the reserviour it bleeds itself by the bubbles rising to the top.
    VS III 5spd Ute
    Apr 2010
    Lake Macquarie
    If you are talking about the low pressure hoses from the resovoir ensure that the resovoir itself hasn't been cracked. I replaced mine to find it was the actual plastic where it sits against the body rather than the hoses which I first thought.
    VS Caprice SII
    Mar 2007
    Northern Suburbs
    cheers smokyj they are the low pressure hoses i am looking at replacing. they arent leaking yet thewy just look really shitty
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    When you change them, first use a syringe or something to remove the oil from the reservoir to reduce the amount of fluid spilt. Use care when undoing the hose clamps as the plastic reservoir gets brittle with age....same goes for when you do the hose clamps up after replacing - do not overtighten. Then fill with new Dexron111. New hoses are under $20 each from Holden but expect only a few years life from them as one goes rock hard and the other soft like jelly.
    VZ Commodore Wagon and EH holden
    Sep 2010
    nowra
    If you are going to replace the cooler hoses they usually need 2 clamps either end for better sealing
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by hako View Post
    Easier solution to removing old hose. Take the clamp fully off. Slice along the hose the length of the spout and remove it that way. Way to easy to snap the spout of and a replacement is in the vicinity of $160 new from Holden.
LinkBacks (?)
  1. [VR V6] replacing all radaitor hoses, power steering hoses, etc need help
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2010, 08:40 PM
  2. How are your power steering hoses?
    By hako in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2009, 11:42 PM
  3. Power steering return rubber hoses
    By Promotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2009, 01:47 PM
  4. Power steering hoses
    By greenvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2009, 10:37 PM
  5. VS power steering change
    By ss16 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2005, 12:29 PM
