Results 1 to 24 of 24
Thread: VR Statesman 5.0 Starting problem
    VR Statesman
    Nov 2010
    Yanchep
    Default VR Statesman 5.0 Starting problem
    Hi Guys just wandering if some one could help my statesman will start after the car has been left for 12 hours or so and run but it runs very rich blows lots of fuel out the exaust and black smoke it seems to find its self after a minut or so if i give it a few revs it seems ok i can drive it no problem but if i turn it off it wont start again it just turns over freely with out even a fire unless u hold your foot flat then it will fire and stummer and carry on but wont start iv replacet the Trottle Positioning Sensor and the Map Sensor but still does the same its getting plenty of fuel so thats not the issue please help.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Probably need to clean out the throttle body and the IAT (input air temperature) sensor. Also check your air filter to make sure it's not blocked.
    VR Statesman
    Nov 2010
    Yanchep
    Throttle body has been cleaned ,Air filter is new Ill try cleaning the IAT thanks for the help
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    vs commodore
    Oct 2009
    Tamworth NSW
    Definitely check for leaking fuel injectors,the hard starting and black smoke on startup are classic signs of leaking injectors.
    VP S2 BT1 5L / VS V6 Exec
    Sep 2005
    Could also be a faulty distributor or coil, as unburnt fuel and hard starting can be associated with that also...but check injectors first as they are the easiest to eliminate and get to...
    VR Statesman
    Nov 2010
    Yanchep
    Quote Originally Posted by hsv91ss View Post
    maybe leaking injectors causing it to flood?
    Thanks dude u hit the nail on the head it is a leaking Injector!!!!!
    VR Statesman
    Nov 2010
    Yanchep
    Hay all thanks for the help but now I have another problem iv had the injectors done it starts and runs great no smoke but now it has a miss but only when u flatten it free revs no problem and don’t miss a beat but when u flatten it driving down the road it starts to get a miss at 3 thousand revs and onwards once driving at 90ks it runs smooth as but when its under load it seems to miss any help would be much appreciated it has had the injectors replaced new Map sensor and new TPS its getting new plugs and leads on Sunday its seems electronic as the taco jumps a little when it misses
    SV6 Commodore
    Nov 2010
    VR Statesman
    Nov 2010
    Yanchep
    Quote Originally Posted by m1chael1o1 View Post
    its a statesman .....theres ur problem
    U got nothing helpful to say why say anything at all !!!!!!!!!!!!!
    v8 comodore wagen
    Nov 2010
    Lebannon
    Quote Originally Posted by Jimmish View Post
    I would have let the OP down slowly but hey, he cut to the chase.
    My mates integra is quicker den my Ve ss wagen.
    SV6 Commodore
    Nov 2010
    Im just helping you in the long run trust me
    VR Statesman
    Nov 2010
    Yanchep
    Yeh well I’m stuck with it for the moment so it at least needs to run right iv tried to hand it down to the wife but she don’t want it so i got to fix it
    v8 comodore wagen
    Nov 2010
    Lebannon
    Is it an auto or manual.
    Did the battery over-derp?
    Check that first or ring the nrma to check
  15. #15
    SV6 Commodore
    Nov 2010
    Just saying sometimes then can be costly and alot of things go and arent cheap, here is an idea would you be interested in swapping it for my goat. Shes 12 months, fully trained, the works basically
  16. #16
    VR Statesman
    Nov 2010
    Yanchep
    SV6 Commodore
    Nov 2010
    Ok your on ill swap
    Sounds like we have a deal...ill prep her and send you pictures tomorrow
  18. #18
    VR Statesman
    Nov 2010
    Yanchep
    SV6 Commodore
    Nov 2010
  20. #20
    Aug 2004
    If the tachometer jumps when it's missing I would be suspecting either the coil and/or the ignition module.
  21. #21
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    I have the exact problem.. How hard are the injectors to replace/clean? Whats my best options?
  22. #22
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If its under load that it misses, i would tend to think dizzy cap. But its one of those magical faults that could be anything, I would tend to think its electrical and would try the following. Hall sensor, dizzy cap, spark plug leads, spark plugs, coil, dfi module.
    For purly a money saving thing start with the cheaper stuff; Spark plugs, leads, dizzy cap and coil. If you get to the hall sensor its probably easier to buy a whole dizzy. If you have a friend sowhere with a efi304, swap the dfi's over to see if that helps the problem before shelling out for one.
    Reaper
  23. #23
    VR Statesman
    Nov 2010
    Yanchep
    It ended up being the dizzycap that was causing the miss the clown that replaced the injectors must of lent on it why changing them
    Quote Originally Posted by Maxxiz View Post
  24. #24
    Aug 2004
    Good to hear you have solved the problem, although I don't see why anyone replacing injectors would have gone anywhere near the distributor cap. It's difficult to get to at the best of times.
LinkBacks (?)
  1. WH/VT starting problem
    By ivanov in forum Electrical Wiring / Questions
    Last Post: 04-09-2010, 06:51 PM
  2. VQ Statesman Starting Problem
    By Bugcatcher in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2010, 02:38 PM
  3. WH Statesman starting issue
    By stockyvrcalais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2010, 06:08 PM
  4. WH Statesman V8 AC Problem - Compressor Starting and Stopping
    By brokenz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2010, 08:59 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
