Results 1 to 9 of 9
Thread: Tips for Consistent Flat Battery
    VS Executive (Bench Seat) Sedan 1996
    Nov 2010
    Default Tips for Consistent Flat Battery
    Hi,
    I have a 1996 VS Exec Commodore Sedan (with bench seat).
    About a month ago the car wouldn't start.
    The NRMA said the battery was old (& checked the alternator was still charging, etc), so they replaced the battery.
    A week later the car wouldn't start again. The NRMA said the battery was flat and needed charging.
    I took the car to an auto electrician who tried to work out what was draining the battery. He couldn't fined anything.
    Long story short - the battery is still being discharged even though it looks like nothing is draining it (remove fuse for indoor lights).
    Any tips on what it could be?
    Many thanks
    Gwbulldogs1
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Perhaps check there isn't excessive current draw when the motor is off. Do you have any after market accessories such as a sound system?
    1992 VP commodore
    Aug 2010
    warner, queensland
    vs commodore
    Oct 2009
    Tamworth NSW
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    if its not charing at all, it can really only be the alternator or the alternator leads.. u can check to see if any accessories are draining the battery whilst the car is off using a multimeter and continue checking the battery voltage say every 5-10mins.
    check this thread werid problems with my VS similar issue and one of the contacts were stuffed.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by ephect View Post
    or you could remove the negative battery lead and measure the current draw in amps.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check it at night in pitch blackness - look for light. Another source of problems is if an aftermarket immobiliser has been fitted - these often fail and result in battery drain.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    get yourself a cheap multimeter from dicksmith/jaycar. then measure the current draw as been suggested above. if there is excessive curent draw, start pulling fuses to find the culprit. can also check the alternator is charging properly
    Body by Holden, Soul by Brock
    the Legend will live forever
LinkBacks (?)
  1. flat battery, how do i get in?
    By 2LOUD2OLD in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2011, 01:57 PM
  2. Flat Battery
    By ciddyau in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-09-2010, 06:39 PM
  3. Flat Battery
    By tr3nt in forum Electrical Wiring / Questions
    Last Post: 31-05-2009, 07:07 PM
  4. VQ Battery Going Flat
    By VQ Stato in forum Electrical Wiring / Questions
    Last Post: 11-07-2005, 04:29 PM
  5. Flat Battery
    By Randy18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 12:38 PM
Tags for this Thread
