go easy on me as this is first post and its more than likely in the wrong place! i've got an oct 95 vs with factory lpg fitted and recently the heater tap broke 2 k's from home in the dark.did a quik fix and plugged the hoses. the engine started to cut out on the way home and it clicked i'd cut off the hot water to the convertor.the way it cut out was different to any freeze ups ive had in other lpg cars,seemed electrical as though someone flicked a switch then 10 seconds later full power again.
renewed heater tap,hoses etc and now it wont start on lpg and will only idle on petrol and not rev at all.ive spent last few weeks eliminating all error codes (19,21,35, and more i forget) and checking wiring,earths,trying another ecu with and without original memcal. it will run at idle on lpg if u hold the "purge" button on the convertor in
theres 2 "vac pump"things that go to the mixer and one is going non stop now and green light on lpg controller keeps time with it. wen it idles red light goes out and green goes solid. (attached pics) this other post seems very close to whats happening http://forums.justcommodores.com.au/general/149662-vt-commodore-does-not-rev-up.html im thinking its the lpg controller but im outa clues. if anyone can help id appreaciate it bigtime.
