Results 1 to 8 of 8
Thread: berlina, lsd or standard diff?
    vz tonner
    Aug 2010
    adelaide hills
    Default berlina, lsd or standard diff?
    hey, just a quick question. i have a 1996 vs berlina v6, and i was wondering whether my car has a optional lsd in it or just a standard diff?
    i have read somewhere that the diff's were optional in this model. is there any way of checking? codes on diff housing, things to look for? and no i dont wanna go out and leave some black marks to go check either...
    im leaning towards that it does but im not sure, eg. the other day taking off i had one rear wheel in the dirt and one on the bitumen. i gave it too it and to my suprise the wheel in the dirt didnt spin its self out. it just took off with out even feeling like one wheel was in the dirt.
    vs berlina s2
    Feb 2009
    Diff could be flogged out. Get under the car if its a stock unmolested car you will see "high performance" tag on the right hand side rear of the diff. mine used to do what ur explaining....my diff went kaboom not long after now i have an lsd.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Look on your diff, there should be a tag that says 'LSD - High Performance'.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VS II 5 ltr Berlina Wagon
    Apr 2004
    Looks like this on diff when you look at it from behind you car
    Attached Thumbnails Attached Thumbnails berlina, lsd or standard diff?-lsd.jpg
    Mmmmm V8
    tim005's Avatar
    tim005 is offline Yet Another VS Ute Owner
    99' Series 3 VS S-Pac Ute.
    Feb 2009
    Melbourne.
    If you have a hoist or youi can somehow jack the rear of your car up you can check.
    If you spin one of your wheels and other spins with it you have an LSD.
    If only one spins you have a single pegger my friend.
    http://forums.justcommodores.com.au/...first-car.html My VS Ute, 99', S Pac, 5 Speed.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by tim005 View Post
    I thought if one spins and the other spins the opposite way you have a single pegger?
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by jokerflingo View Post
    You are right,this is the way to tell if the diff is LSD or not.Jack up the rear of the car, spin one wheel by hand, the opposite side wheel will spin the opposite way on a single spinner.If both wheels turn the same way,its a LSD.
    tim005's Avatar
    Feb 2009
    Melbourne.
    sorry, i must have got mixed up.
    well, what he said then....
  1. [VIC] FS: Standard IRS Diff from VS statesman
    By Deneo in forum Parts And Other Items For Sale
    Last Post: 08-07-2010, 08:01 PM
  2. [SA] ls1 trans and standard diff
    By 13BT_RX2 in forum Parts And Other Items For Sale
    Last Post: 16-12-2009, 04:14 PM
  3. standard vr diff ratio?
    By benny mckellar in forum General Discussion
    Last Post: 19-03-2008, 11:19 AM
  4. VX SS standard diff ratio
    By VSIIBerlinaL67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-06-2006, 01:05 PM
  5. Replacing the standard diff with LSD
    By CustomVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 05:28 PM
