Results 1 to 8 of 8
Thread: VR / VS LPG compatibiliy
    VX SS
    Jun 2005
    Default VR / VS LPG compatibiliy
    Just wondering if a LPG system from a VR will fit up fine to a VS or not?
    Im looking at buying a second hand LPG tank and fittings and then getting it put in my VS.
    Thanks
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    So much cheaper to just go and get a new one installed from an accredited LPG installer.
    Cost me $400 out of pocket for the conversion.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VX SS
    Jun 2005
    Ive already claimed the rebate on another vehicle I had and there is a period of three years where you cant claim.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Ah ok. The gas system itself should be fine, though you need new copper lines, new fuel lines etc etc etc. Ring a gas place and check. Going Direct injection or mixer setup?
    1997 VS II - S
    97 Vs commodore Esteem series II
    Nov 2010
    Bargo nsw
    Hello I am new to this site,
    just bought a VS sII 1997 with lpg and petrol having some trouble with car back firing through the air filter have changed plugs and new leads
    It runs fine in cold weather but on hot days it start to backfire . Also when running on petrol runs ruff in hot weather
    Could this be the censer on the harmonic balance been faulty ? Any help would be very appreciated
    Thank you
    Glenn
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Quote Originally Posted by milesgt View Post
    Thank you
    Glenn
    Its usually ignition - plugs should be one range colder - drop the gaps to 1mm if these are all ok then its coils or dfi module playing up tryout Pulstar plugs - they have stopped all my backfiring even though I had two coils fail - do a search on u tube & check out dyno tests on sparkplugs,com 411.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Thank you
    Glenn
    What you have described is an ignition problem. There are a number of things that it could relate to:
    1. Coil Pack
    2. DFI Module (Computer chip under the coils) - When this has an issue, backfiring is a key symptom.
    3. Leads (not carrying enough power/current/spark)
    4. Spark plugs
    1997 VS II - S
    Nov 2009
    Bundaberg
    Liquid injection is the bees knees - but If your going positive converter - get a variable Blos mixer from Ebay the std one is very restrictive - with this you wont lose any power. Get a dual map memcal - you wont need a petrol start then as the computer starts it on petrol & then switches them & the fuel pump off - then you have the correct ignition map for LPG. Make sure your ignition is up to speed & run colder plugs & close the gap down to .7 - 1 mm better still get the Pulstar plugs do a search on you tube & google - dyno proof on sparkplugs.com / 411
    They will stop any backfires - not many people know about them here but huge in the states - they will fire the plug until the coil just stops - no backfire at all. These three things make my car run just like it is on petrol but better - no loss of power - easy starting & cheaper & simpler than what many people fit. With the memcal it comes up on LPG straight away - you just have to run a wire from the changeover switch to the pcm - there are certain models of pcm that it works with though & that info is available on the site - just do not know how to send you the PDF file through the forum - you can find the correct way to wire it all up at Apexus including using your petrol gauge to read the lpg tank - if you want more details on the memcal just let me know - but most big LPG supplier's should be able to supply it & the pin you will need - memcal is around $140
    Welcome to the APEXUS Pty. Ltd. World Wide Web Site
    This is the link to the Pulstar plug supplier in Qld
    Hiclone, Fuel Economy, Hyclone Fuel Saver Pulstar Pulse Plugs Petrol Diesel LPG - Home
