Results 1 to 14 of 14
Thread: question
    vs commodore
    Aug 2008
    Default question
    hey i am having troubles with my vs v6 and found this wondering is this supposed to be here
    Attached Thumbnails Attached Thumbnails question-100_0383.jpg   question-100_0384.jpg
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    vs commodore
    Aug 2008
    the hole that can be seen in the middle of the pics beside the thermostat
    VS S-Pack SII
    May 2008
    I'm not having a dig... but i hate when people post a thread with a single worded "non relevant" topic... the point of the topic name is to give people an idea of what the thread is about... it would also help others if you specified what youre talking about? the electrical plug? the hole? dirt? a space invader???
    Anyway, taking a guess, youre asking about the thread hole??
    If i am correct, i believe its just an unused thread... but a zoomed out pic would help others to triangulate exactly where it is...?? (Where exactly behind the thermostat housing, there are a few bolts/holes behind there...)
    vs commodore
    Aug 2008
    sorry about short question its located behind the passenger side of the thermostat yeah it is the hole there is no thread in it at all
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    You're missing a valley/inlet manifold bolt, thats why you have a hole there. There's no thread in the alloy, but there will be below that in the cast iron cylinder head. Head to the wreckers to remove one and replace your missing one. This could be causing an air leak with it missing which would result in an irratic/uneven idle.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    vs commodore
    Aug 2008
    thanks but would it also cause a build up of carbon on no 6 spark plug at all?
    Aug 2008
    NSW South Coast
    No, that's a seperate issue causing that. Not sure what though sorry.
    PM Me For Details
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    The hole is just a hole, unused, nothing to it, the intake manifold runs past it and has nothing to with it. Every V6 i have seen is the same. Carbon buildup could be a number of things, week spark from coil pack to the plug, a bad plug/lead or a number of substances contaminating the mix. Can you give us any more info?
    vs commodore
    Aug 2008
    its missing like a bitch back firing etc yesterday it popped a injector out on cylinder number 2 i have fixed that issue by putting bolts in i have put a bolt into that hole anyways found one in my shed from another ecotec its having trouble starting not wanting to start and not running right at all i put new leads on not long ago same with coils and put new plugs in yesterday
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    back firing is usually running to lean or to rich, have you checked for fault codes Checking error codes VR/VS (Revised) ? I dont know how it could pop an injector out as there bolted in by the pelium, the fuel pressure could be to high or the orings on the injectors are stuffed, if the fuel pressure is to high then it would be running to rich.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by The1 View Post
    Um, don't mean to get off topic, but you might want to have a little closer look... No hole in an ecotec manifold is unused. There will be a correcponding thread in the head under this hole. If you've seen many like this then they've all been missing this bolt
    PM Me For Details
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    you are correct, i couldn't really see in the photo, that photo has the bolt missing in the intake manifold correct, there is a bolt right next to the manifold though in the head itself which isn't used, which was what i was referring to
    vs commodore
    Aug 2008
    i have the 25mm intake manifold spacer so had no bolts holding it down hence popped out and yeah cander24 is right there is a thread for a bolt to go in there i just found one from a ecotec i stripped down and put it in there which is in there properly
  1. Not another cop car question!!
    By Colby844 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-12-2008, 06:43 PM
  2. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  3. Question about reg..
    By tyneesa in forum General
    Last Post: 14-11-2005, 06:23 AM
  4. efi vk 6 question
    By SUSPECT in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-10-2005, 03:27 PM
