Results 1 to 18 of 18
Thread: vs t5 conversion
    Manual vs s pack
    Mar 2010
    cant tell
    Default vs t5 conversion
    hi all, recently just done my manual conversion on my series1 vs s pack. done on the weekend actually.
    i have the manual gearbox loom and manual computer, no wirings been done yet. just plugged my computer in. it stalls when coming to a stop and no reverse lights my auto switch i have to mess around with when starting.
    just want to find someone that could give me all the answers needed to wire up the gearbox loom, and inhabitor switch? and my speedo.
    thanks in advance guys.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    Hey man had same problem with my vt manual conversion, once u hook up the speed sensor it will stop stalling or just give it a quick rev when u are comin up to a stop to stop it stalling
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    vs berlina s2
    Feb 2009
    mine did this. i found i got the ecus mixed up on the back seat and i put the aut ocomputer back in. and also can ya get hold of the car to get the conversion out of there is a factory loop of some kind that earths out the start switch. if u can get hold of that makes life easy
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    Or all u gotta do is find the 2 wires that go to neutral switch and put female plug on one and male plug on other and plug em together: done! On vt the 2 wires are grey and grey with blue trace and from memory vn wires are grey and pink
    VT V6 Manual turbo
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    U can also hook up a switch in between these 2 wires and u got urself a killswitch so no one can start car
    VT V6 Manual turbo
    Manual vs s pack
    Mar 2010
    cant tell
    thanks man, now just to figure out the speed sensor... and reverse lights, did you do yours or get an auto elec?
    Manual vs s pack
    Mar 2010
    cant tell
    and fonzo i cant get a hold of the car it got crushed unfortinatly. just gotta figure out this speedo thing, and im considering going to look at which comp i put back in lol
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    If u use the t5 speed sensor u gotta give it power and earth then hook up the wire after the computer... If ur car got abs I spliced a wire from the abs sensor on right rear and ran it through 2 speedo corrector then into the blue wire off the auto plug which goes to the ecu. For reverse lights that's easy just gotta find which 2 wires go to it then put 2 female plugs and hook em up to the t5 sensor. I'll look 2moro for u what wires they are
    VT V6 Manual turbo
    Manual vs s pack
    Mar 2010
    cant tell
    i got the t5 box loom. but thats all i got, and do i connect it to the auto one or what? reverse lights hook up to which and omg im so confused.. in the manual box loom it has a connector that goes to the reverse bit and another just layin around that area cable tied to the crossmember. do they just need power and earth or hook up elsewere?
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    There will be one sensor with 3 wires thats the speed sensor then another sensor with 2 wires that's the reverse sensor
    VT V6 Manual turbo
    vs berlina s2
    Feb 2009
    oh i didnt have this problem i changed engine loom at the same time. gearbox pluged straight in without any mods.
    Manual vs s pack
    Mar 2010
    cant tell
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    When I did my vt conversion I bought a vr/vs auto to manual conversion thinking it would fit lol but no... I still have it and also instruction at my old house so I'll try get it tomorrow for ya
    VT V6 Manual turbo
  15. #15
    Manual vs s pack
    Mar 2010
    cant tell
    thanks mate would be appreciated, just went for my licence and failed dog tester.
    so anytime is fine
  16. #16
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    Hey man didn't get time today to get it, I'll try get it tomorrow for ya after tafe
    VT V6 Manual turbo
  17. #17
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    Alright so I got the paperwork today:#
    So for the speed sensor:#
    On the passenger side behind the glove box there is a plug that comes from ur ecu and that goes behind ur dash to ur gauges. On this plug there is a purple/white wire, cut it on the side that goes to ur gauges. Extend the purple/white wire on the t5 speed sensor and connect it to the wire that u have just cut (once again make sure u connect it on the right side otherwise it won't work. Then run a 12V accessory power to the pink/blue wire on the sensor and earth the black/white wire.
    For reverse lights:
    On the auto shifter plug there will be 4 wires. The grey and grey/black need to be connected together so that the car can start in any gear (neutral safety switch bypass). The other 2 wires, pink and green are reverse lights just put female plugs on the end of these 2 wires once u extend them to the gearbox reverse sensor and plug em on. I don't think it matters which way u do it and if it does just swap em once you've tried.#
    Good luck!
    Also one quick question, is ur car a Buick or Ecotec? Coz this is guide for Buick lol
    VT V6 Manual turbo
  18. #18
    Manual vs s pack
    Mar 2010
    cant tell
    ahh dam mines a geekotec..
    i know the reverse lights and inhibitor switch and getting quoted today on the speedo.
  1. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
