Results 1 to 6 of 6
Thread: Using EFILiveV4 to monitor car...
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Default Using EFILiveV4 to monitor car...
    Was wondering if anyone in the know with EFILive could give me a hand with it, I just installed a kit with the evaluation version to monitor my VR V8 and im noticing that on the "dashboard" the O2 Filtered I/P constantly flickers between Rich and Lean, and under "Charts" the mV reading for the O2 sensor constantly spikes up and down drastically. Is this normal behavior or is my oxygen sensor faulty? I also notice that under "flags" the fuelling mode changes between open loop and closed loop sometimes when accelerating, even when the car is warmed up.
    Also just as a general question, are the DTC codes under the DTC tab actually trouble codes recorded by the ECU? because I have 13, 14, 15, 16, 17, 18, 19 and 21 listed.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Hmmm, mine didn't have those under DTC so mabye fault codes but not too sure on that. Do you have a tuner? Take a data log and send it to them to have a look at.
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Also probably should mention it has a foam tune, so if those codes are actually trouble codes, im wondering if he's tweaked it on purpose, ie: 19+21 TPS stuck & TPS high voltage for harder auto shifts? also, 13 - No oxygen sensor signal (custom A/F ratio?) 14, 15, 16, 17 - Coolant temp circuit faults (tweaks for extra power eg: improved ECM control on hotter engine)?
    As far as I know, I've never seen the CEL light up with these codes, I always just get code 12 and sometimes 31 when I dont push the key hard against the ignition barrel.
    The hall of fame:
    ಠ_ಠ
    Nov 2005
    Warrnambool
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the O2 sensor is suppose to oscillate as you have described.
    reset the error codes and see if they come back.
    Body by Holden, Soul by Brock
    the Legend will live forever
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    check the error codes manually, alot of the xml's in the stock efilive dont work properly with dtc's, the xml i made should work correctly, i havn't tested on V8 but on V6 VS it works. If you dont have it i did post it up in the tuning forum, otherwise pm me and i can send it you.
  1. Monitor help...
    By Grennan in forum The LAN Lounge
    Last Post: 07-03-2010, 02:27 PM
  2. Flip down monitor
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2008, 05:54 PM
  3. Looking for a new monitor
    By stocky in forum The LAN Lounge
    Last Post: 02-10-2008, 11:45 AM
  4. Need Help With Installing Monitor
    By ^Porter^ in forum Car Audio
    Last Post: 02-03-2007, 12:33 AM
  5. monitor
    By 1trkmnd in forum Electrical Wiring / Questions
    Last Post: 26-06-2005, 02:48 PM
