Results 1 to 3 of 3
Thread: VR starting problem
    vr v6 commodore
    Sep 2010
    gatton
    Default VR starting problem
    i have a 94 VR V6 manual commodore and im having problems with it on start up
    it has no problem turning over but it just wont fire, generally when hot
    if anybody has had this problem and fixed it or knows what the problem is i need help
    the car has new spark plugs and leads, the fuel pump buzzes when ignition is switched on, so any help would be greatly apprectiated,
    thanx
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    crank angle sensor, it lives on the right hand side next to the harmonic balancer, poor some cool water over it when it wont start then try again, sometimes it will help it work again to get you going.
    vr v6 commodore
    Sep 2010
    gatton
    thanx mate ill give it a try next time it happens, forgot to mention it only happens occaisonally
LinkBacks (?)
  1. 03-06-2011, 07:29 PM
  1. VR Starting problem HELP
    By matttid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2011, 11:18 PM
  2. [SA] VT starting problem
    By jaw308 in forum General
    Last Post: 26-03-2010, 11:03 AM
  3. starting problem
    By big balls in forum General
    Last Post: 27-01-2009, 12:02 PM
  4. Starting Problem
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2007, 11:07 AM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
