Results 1 to 7 of 7
Thread: Has anyone bought the mace ultra high ratio roller rockers??????
    vs commodore
    Sep 2010
    wyongah,nsw
    Default Has anyone bought the mace ultra high ratio roller rockers??????
    hi guys i am just wondering if anyone has bought the mace ultra high ratio roller rockers for there vs-vy v6 ecotec engine as i have 3 questions.
    1.how much of a noticable gain did u get?
    2.is there any extra things u need?
    3.does it need to be tuned?
    i am thinking of installing them into my vs v6 it has CAI and a 2 1/2" exhaust cat back but am tossing up between this or a cam any help would be great cheers
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    doesn't need to be tuned but gains can be had with a tune. It depends if you want longer duration or larger valve opening. Some use a small cam with a higher than stock ratio rocker for best of both, depends on money really. But value for money make rockers best bolt on mod.
    vs commodore
    Sep 2010
    wyongah,nsw
    thanks champ the power gains of both as stated on the website show that gains are about the same.can anyone tell me how much of a power difference they have noticed???
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Well they are guaranteed to give a 16-26kw gain. So depending on how much else of your motor you have modified, i.e. intake, exhaust etc, if it's the right combination of products with the right tune you should gain more.
    Look around some of the MACE review threads, also look at a couple of the VS's in the my ride section who have bought them.
    You can't really go wrong with Rockers, unless you buy the 1.98's and then buy an off the shelf cam, then your up shit creek basically haha.
    My advice:
    How much do you want to spend?
    • If money is no question, go for the 1.91 rockers and talk to Steve at MACE and get a suitable cam
    If you just want a bit more power and don't want to spend upwards of $2000 (for cam supply and install), then just get the rockers.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    vs commodore
    Sep 2010
    wyongah,nsw
    ill do all the work myself but if u get the same gains out of rockers than a cam then id rather the rockers cause its alot let work.im thinkn ill probly go rockers and a memcal chip.seems to be the best value for money on sum good gains
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    I, personally would go with a high lift high duration cam with true roller rockers close to stock ratio.
    No sense getting a low lift, high duration cam to suit high ratio rockers that dont have rollers in the tips.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Do both mate, more power. Better combo.
    1997 VS II - S
  1. Ultra high ratio rockers
    By VT_Six in forum Mace Engineering
    Last Post: 18-03-2010, 04:50 PM
  2. [VIC] WTB: High Ratio Roller Rockers for VR V6
    By matt089 in forum Swap / Wanted to Buy / Trade
    Last Post: 30-09-2009, 05:20 PM
  3. High Ratio Roller Rockers
    By VSSECO in forum V6 Development And Modification
    Last Post: 20-03-2008, 11:18 AM
  4. High ratio roller rockers
    By blaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 11:35 PM
  5. High Ratio Roller Rockers
    By Griggsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2003, 10:11 PM
