Results 1 to 10 of 10
Thread: Injectors or fuel pump please help..
    vr wagon
    Aug 2010
    vic
    Question Injectors or fuel pump please help..
    Hi there,
    My automatic VR wagon is having some problems running, its like its not getting enough fuel. To get it started you have to hold the throttle on or it dies, the revs drop right down and it stalls. It has issues with take off and you feel the power drop in and out at certain speeds. I have changed the fuel filter and still no improvement. Any suggestions, as I want to try fix it this week.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    i'd guess the pump. can you hear the pump straining ? assuming its an electric pump.
    Does it begin to drop out more at high revs ?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Pumps either work or they don't. I'd do a fault code check and see what that throws up: Checking error codes VR/VS (Revised) Another priority would be to clean the throttle body and the idle air control (see the how-to section) as they both control idle speed. How are plugs and leads?
    Injectors may be dirty but to replace costs a few dollars so I'd leave that till last although maybe a can of injector cleaner may not go astray. Also check the fuel pressure regulator - pull the vacuum hose off the regulator and check that there is no fuel in it - if so it means the diaphragm in the reg is busted.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    hmmm , the pump in my VS died a slow death including surgeing / dieing at high revs, constant noise etc etc, and this was after 200000 + k's.
    Servo round the corner changed it and problems all solved.
    Whatever works for you i guess.
    vr wagon
    Aug 2010
    vic
    Fault codes show slipping transmition and vaccuum leak which showed up last week when the car conked out on me last week whilst on a roundabout. IAC cleaned last month so was throttle body. Plugs were replaced at the same time, leads replaced last week. Will check the fuel pressure regulator. Is there any way to check the injectors for blockage?
    greenacc's Avatar
    VE Berlina
    Jul 2008
    There are a few tricks to test injectors im no expert on them, but, with engine idling pull the power lead off each injector one at a time. listen to the engine, if it dies that injector is ok, plug it back in and try the next one, if you find 1 cylinder where it makes no difference when you unplug the injector then that injector aint working.
    1994 Vr Commodore
    Nov 2010
    Hervey bay
    Today our vr started to loose power and shudder like if its not firing properly, this was under power going up hill, it doesn't stall while idling but when i put the car away its like there is nothing wrong, its kind of wierd, so all temps are fine plenty of fuel no management lights came on, just seems just to do it under power or hill climbing, this was just the last 5 mins of driving when the issue happened..
    vr wagon
    Aug 2010
    vic
    found my problem, had to replace main earth lead to engine mount, and the coil pack is rooted, causing plugs to crack and become shot.... changed spark plugs and runned like a dream all day now 2 of them are rooted again lol new coil pack tomorrow and yeee ya, earth lead was causing it to stall and run like crap ontop of the fact it has only been running on 4 cylinders...
    1994 Vr Commodore
    Nov 2010
    Hervey bay
    Resolved buy just replacing a failed coil pack (3/6) but replaced all of them... seems to of resolved the miss whilist at trafic lights or stopped in drv, the miss could be a symtom of a coil pack to fail in the close future or with in 12months..
    vr wagon
    Aug 2010
    vic
    hope not, i replaced them all with vt ones, were exactly the same... running like a dream...
  1. [Buick] injectors,fuel pump and presure reg and air filter combo help
    By matty m in forum V6 Development And Modification
    Last Post: 26-05-2010, 10:44 PM
  2. [VIC] bosch 044 fuel pump, surge tank and injectors
    By Troy5L in forum Parts And Other Items For Sale
    Last Post: 08-01-2010, 05:08 PM
  3. [VIC] Fuel tank & reco fuel injectors
    By BT1-355 in forum Parts And Other Items For Sale
    Last Post: 25-11-2009, 03:36 PM
  4. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
