Results 1 to 7 of 7
Thread: Start-up problem
    VY Berlina
    Mar 2009
    Sydney, Australia
    Question Start-up problem
    Hey everyone, just a quick question.
    I am thinking of buying a mates VS Calais. Only negative thing I know about the car is that sometimes, to turn on the car, you need to put it in reverse or neutral (can't remember exactly which one he told me) and then into park whilst twisting the key in the ignition. Does anyone know what the cause of this could be? I was thinking maybe an immobiliser could be doing it (if one is installed) or the ignition itself... My mate doesn't know what it is as he's never had the problem looked at; he's just gotten used to the fact.
    I'm just hoping it's nothing to do with the transmission or anything. And if you haven't noticed yet and before you ask, it is an auto.
    Thanks guys!
    PorkoWogVisit MeContact
    Looking for or in need of free or paid hosting?
    Please contact me now for more information.
    vs commodore
    Oct 2009
    Tamworth NSW
    It sounds like the auto trans neutral safety switch under the console near the gear shift lever is stuffed..Its easily replaced..
    VS Series II Supercharged Statesman
    Nov 2010
    I second that vote (parking inhibitor switch).
    mine started playing up a while ago and I had to 'lean' on the gear shift in park to start it.
    luckily the problem has gone away, but i will get to changing it one day if it starts to re-occur as two different mechanics suggested if it fails there will be no starting the car until it is replaced.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    VY Berlina
    Mar 2009
    Sydney, Australia
    Music to my ears.
    Thanks for the replies guys. Sounds like an easy fix then. Any idea on how much it will cost me to get it replaced/fixed?
    VS II
    Aug 2010
    You can replace the unit yourself, remove the panel around the gear shift, disconnect the wiring for the cig lighter and pull out the ash tray, twist the plate 90 degrees and lift it off... do a search on VR/ VS stereo removal for the procedure as this part needs to be removed in order to get to the stereo.
    Once you have removed it you will see a little electrical unit screwed in next to the gear shift. There is a thread on here, its about reverse lights not working on vr/vs , caused by a fault in the same part. You might be able to clean to fix (see reverse light thread) or may need to replace.
    Drew
    VY Berlina
    Mar 2009
    Sydney, Australia
    Awesome, thanks a lot Drew. If I end up getting the car I'll give it a go myself and hope for the best. Thanks everyone for the help!
  1. start up problem with gas
    By Fizzman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2009, 06:11 PM
  2. start up problem
    By bboystyles in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2008, 07:56 PM
  3. problem on start up
    By seans VL Calais in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-05-2008, 10:19 AM
  4. Car start problem
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2007, 09:12 PM
  5. Lpg start problem
    By fullymetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 12:32 PM
Tags for this Thread
