Results 1 to 11 of 11
Thread: Trans draining 4l60e
    vp wagger
    May 2008
    Default Trans draining 4l60e
    im guessing the only way to drain a small amount of fluid from the tranny is to remove the pan ???? why the heck doesnt it have a drain plug ??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    No autos have drain plugs - not since the 50's. Just undo one of the oil cooler hoses where it joins the radiator cooler - run engine for 10 secs or so. Easy.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Yeah be very careful with doing it the way hako said. The auto is fairly high pressure so the oil will spurt out like no bodies business. Yes I have learnt this the hard way.
    Mar 2008
    unless you feel like taking your tail shaft out , but if you do mark it so it aligns the same way
    if you or a mate is handy on a welder you could put a sump plug in the pan
    thought its not going to help you at the moment
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    You can also buy aftermarket pans with a sump plug in them, usually on ebay if not they're always on the US ebay. Get a decent quality one though, not some cheap crap that'll crack when it warms up a bit.
    Also, I've found that there is usually enough oil in the trans lines to and from the radiator that you can get a decent sample without having to have the engine running when you undo them. Depends how much you need though I guess.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    use a brake fluid sucker and push the tube down the fill tube
    oh and note mearly all new gearboxes dont have a dipstick and have a fill plug in the bottome of the auto pan
    this is too stop people who incorreclty check their fluid from draining too much out or refilling it with the wrong fluid
    causing long heaterd arguments with warranty from holden
    vp wagger
    May 2008
    kewl banana's guys thanks for the tips i tried to suck some out of the dipstik tube but it wont go all the way down into sump must be a plate or bloker there but will try the cooler line .....b&m have a deep finned sump for the box but 250-280 u.s.a. puk dat :/ will just drop the sump if all else fails
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    sometimes need to have car running to suck oil out of auto.. wait a minute
    you do have the car running to check the auto level right?
    vp wagger
    May 2008
    yep notso it still going atm it is just a hack to get work etc and i was going to put some morey's leak and slip sh*t in but it is too full rofl ."the rat just cant be killed"
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Pull the speed sensor outa the trans and drain it from there .
    vp wagger
    May 2008
    sweet thanks dayvo have to replace the o-ring in the sensor anyway so kill 2 birds with one rock
LinkBacks (?)
  1. 08-07-2011, 11:41 PM
  1. 4L60E trans dignostic info
    By moff_man in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2010, 11:31 PM
  2. Problem with VR auto 4L60E trans not going into 4th
    By alpha_au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2009, 11:50 AM
  3. [VIC] WTB-Auto trans 4L60E either 3HDD or 4HDD
    By MG's VH Wag in forum Swap / Wanted to Buy / Trade
    Last Post: 04-02-2009, 08:02 PM
  4. Dropping a 4L60E trans
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2006, 05:28 PM
  5. Trans Service on 4L60E
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2006, 01:27 PM
