Results 1 to 15 of 15
Thread: VS temp gauge signal wire
    Vs commodore series 2 supercharged v6
    Oct 2010
    Bunbury
    Exclamation VS temp gauge signal wire
    Hey dus any 1 no wut colour wire the temp gauge signal wire is and wuts the other wire coming out of the sensor??
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    Oct 2010
    Bunbury
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    okay hang on
    crap that wiring diagram is on my laptop give me 5 minutes okay?
    Oct 2010
    Bunbury
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    coolant temp sensor
    connector ye106
    yellow wire goes to power train control module
    othe wire goes to ground internally in ecu as a reference
    why do you need this info?
    i am assuming from my diagram it has two wires coming out of it?
    so signal wire to ecu is yellow and the
    Oct 2010
    Bunbury
    Jus need to know what wire to hook up to temp gauge as old dash has been ripped out as its a burnout car.... And dont know what colour wire is the temp signal behind the dash...
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    temp signal at the instrument plug? at dash the one i gave you is at the sensor hang on i will look up ipc wiring
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    in my diagram it says that it is part of the signals sent and recieved from ecm (engine module)
    for a burnout car you may be better off just running a wire from the sensor or buying a gauge with a sender (temp are pretty cheap)
    Oct 2010
    Bunbury
    But i got old sensor plugged in and jus wanna no wut colour the signal is behind the dash so i can jus plug it in, already got a elec temp gauge...
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    well my diagrams dont say it says one wire does overheat engine oil and water and auto trans so.....
    easiest way to find out is to use a multimeter on ohms and go from sensor plug with one end and other end probe ewach of the wires at the ipc plug if theres one there it will come up as like 10 ohms
    if not run awire straight from the sender into cabin soz mate about all i can do for you
    Oct 2010
    Bunbury
    vs commodore
    Oct 2009
    Tamworth NSW
    Theres two sensors for the coolant temp on the VS engine, a single wire one for the temp gauge in the dash,and another multi wire sensor for the ECU.The VS wiring diagram I have shows a Black/yellow wire, and a plain Yellow wire coming from the coolant temp sensor.(the one for the ECU,not the temp gauge).The yellow wire goes straight to the ECU,actually to ECU terminal pin number B5(middle pink ECU plug).The other Black/yellow wire joins the Black/yellow wire that goes to the TPS (Throttle Position Sensor) from the ECU,or ECU connector terminal E16 (blue ECU connector).The temperature gauge coolant temp sender is near the ECU coolant temp sensor on the front of the engine.It only uses a single green wire from the temp gauge to the sender unit on the engine.
    Oct 2010
    Bunbury
    So your saying the signal wire behind the dash cluster is only a single green wire?
  15. #15
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by Brett_jjj View Post
    ....It only uses a single green wire from the temp gauge to the sender unit on the engine.
    That's just what he said.
  1. RPM signal wire
    By VScommodoreute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2011, 08:22 PM
  2. amp signal wire ???
    By lodgie in forum Car Audio
    Last Post: 28-02-2010, 04:27 PM
  3. water temp/oil psi signal wire
    By sycvs in forum Electrical Wiring / Questions
    Last Post: 07-11-2009, 01:53 PM
  4. signal wire for air fuel gauge
    By guyver6 in forum Electrical Wiring / Questions
    Last Post: 09-10-2006, 08:49 AM
  5. MAP signal wire
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2006, 04:19 PM
