Results 1 to 8 of 8
Thread: Intermittent stalling and restarting issues
    VS Commodore Executive
    Feb 2009
    Default Intermittent stalling and restarting issues
    As far as I can tell I have a very similar problem to the member in this thread:
    Engine stall
    I had issues recently and in the last 6-12 months I have replaced the fuel filter (new), plugs and leads (new), DFI module with coil pack (used), fuel pump (new) but have now developed ANOTHER problem. I first noticed it about 2 weeks ago when I slowed down to make a turn off a very busy road. The engine just died and I was left in no-man's-land trying to get it started. I managed to get it to fire a few times but only enough to make it another hundred metres. After a while I started it without a problem and drove away.
    Today, I was doing a 100km round trip and on the way back the car just died. I tried to start it but it took until I had slowed down to about 40kph before it fired and stayed started. I managed to get up to 100kph again when it did it happened again. Once again it took a while before it stayed started and after angrily bouncing it off the rev limiter for a few seconds I continued on problem free.
    Later today it drove fine until I had to stopped it and tried to restart it. It took several minutes and then started.
    I have read all the different comments relating to CAS, BCM and a few other things in the other threads but none seemed exactly like my problem.
    Any help would be hugely appreciated.
    Cheers!
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    I reckon its the Crank Angle Sensor mate. Sounds like once it heats up, it packs up.
    Fairly common.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    vs commodore
    Oct 2009
    Tamworth NSW
    Check for error codes.Heres a link to a post that shows you how to do this.---Checking error codes VR/VS (Revised)--- Theres a big chance of it being the CAS though,and they dont always set error codes when they stuff up either.If it is the CAS,try to get a genuine holden one.Some of the cheap ones are rubbish and can cause even more problems.
    Feb 2009
    Quote Originally Posted by greenacc View Post
    and the fault codes are ?
    It gave codes 12 and 49. 12 is ok but 49 is:
    Code 49 - Crank or Cam angle Sensor Intermittent
    Sort of speaks for itself doesn't it? :-( Well, I guess I know what to replace now. I just have to get a hold of a seriously long breaker bar and go crazy on the harmonic balancer. Hopefully I should be able to get out of trouble (by doing it myself) for a little over $50.
    Thanks again for your help everyone.
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Feb 2009
    Quote Originally Posted by VR_Acclaim View Post
    I got 49 to but it was my fuel pressure reg
    The old one CAS is coming out tomorrow and the new one is going in. I guess I will find out when the first hot day arrives
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Dannal View Post
    You will need a 3 bolt type harmonic balancer puller,dont get the 3 leg type.You will also need three 1/4 UNF bolts about 2-3 inches long to connect the puller to the balancer.If the balancer is not removed this way,you can stuff it up.The balancer is made of two pieces of metal joined with rubber,and can easily be broken if not removed properly.These pullers are available cheap at places like supercheap etc.Its not cheap to replace the balancer if you stuff it by removing it wrong.Cheers.
  1. VT2 intermittent stalling
    By Saints10 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-08-2010, 12:47 PM
  2. intermittent stalling
    By VTPREDATOR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2009, 07:32 PM
  3. vr v8 intermittent stalling
    By RED50 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2006, 02:16 PM
  4. Intermittent Stalling
    By Normy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2006, 08:45 PM
  5. Intermittent Spark/stalling
    By VSWagon in forum Electrical Wiring / Questions
    Last Post: 29-03-2004, 10:07 PM
