Results 1 to 14 of 14
Thread: VS Ute stumbles after starting
    VS Ute 1995
    Nov 2010
    Inland NSW
    Default VS Ute stumbles after starting
    My ute has been having some troubles of late but the most tricky one to diagnose is why the engine stumbles and carries on for a while after starting , this usually continues for 20 min of normal driving or so, but when its wet or cold its much worse. The longest time it did it for in one go was about 200k (lismore to brissy!) if anyone has a clue why it would be doing this it'd be much appreicated !
    vs commodore
    Oct 2009
    Tamworth NSW
    VS Ute 1995
    Nov 2010
    Inland NSW
    vr wagon
    Aug 2010
    vic
    VS Ute 1995
    Nov 2010
    Inland NSW
    vs commodore
    Oct 2009
    Tamworth NSW
    vr wagon
    Aug 2010
    vic
    check your earth wires, might be one loose... easy way to tell is run a thickish wire from your - (black) terminal on battery to somewhere out of the way on your engine take it for a drive and see how it goes if it works then theres the problem.. worth a try..
    VS Ute 1995
    Nov 2010
    Inland NSW
    vs commodore
    Oct 2009
    Tamworth NSW
    Id start with checking the codes,it only takes a minute or two and is easy to do.
    VS Ute 1995
    Nov 2010
    Inland NSW
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by PorshadrivesaVS View Post
    yeah but i dont know how
    Go into the error checking link I posted above,and scroll down near the bottom of the page,theres some excellent pictures and revised instructions which show you how.It easy.Once you have done it once,you will kick yourself for thinking you couldnt do it.
    vs S3 ute
    Nov 2009
    toowoomba QLD
    mate mine did the same thing one time. i had the gearbox serviced and asked them to check the car over. they reckon they couldn't find a problem and everything was perfect and it never happened after that. so a transmission service fixed mine. didn't throw any codes up either. and it all happened when it was pouring rain one time and i was driving in it for over an hour. since then i've been in worse rain and no worries. cairns and back, no worries...
    VS Ute 1995
    Nov 2010
    Inland NSW
    i checked the earth wire and im gonna take it into the shop in the next few days - thanks eveyone for your help
    vs commodore
    Oct 2009
    Tamworth NSW
    Did you work out how to do the error code check?Did you look at the pictures and read the revised instructions near the bottom of the posts in the link?
  1. Vr: Stumbles/stalls on takeoff?
    By CHA53R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2010, 09:33 PM
  2. VN not starting
    By VN_chris in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2009, 04:21 PM
  3. Stumbles on take off...It can't make up it's mind!
    By Mordred in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2007, 06:38 PM
  4. Vs not starting
    By inoutinout in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 11:18 AM
  5. vn not starting
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 05:30 PM
