hey guys,
having a few problems with my vs engine. more specifically troubles with the sensors on the air intake. the engine starts and runs, but only with the air flow meter disconnected, and when i try to reconnect it, the engine stalls, it also wont rev either, stalls if i try, it only idles, pretty sure this would be due to the air flow meter not being connected tho.
did the diagnostic and the computer spits out code 23 and code 32. these are 23 = air temperature sensor voltage to high, and 32 = air flow meter voltage out of range. just wondering if anyone knows wat causes this and any ideas on how to fix it?
cheers guys
First up check the wiring from both sensors back to the ECU.Maybe test it with a multimeter.If the wiring proves to be ok,then try some different sensors,they might be faulty.Also clear the error codes from the ECU by disconnecting the battery for a minute or two.
