Results 1 to 5 of 5
Thread: Alternator troubles
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Alternator troubles
    The other night my battery light came on, turned out to be a corroded terminal. I just checked the voltage at idle and it's only 12.13V, i've tried 3 different voltage regulators and got the same result, so it's not likely to be that. I've given it a good drive and it still reads the same, what else can I do?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The cable you replaced may be bad further down the line - if it was the thick one at the rear of the alternator, the corrosion can still be in the wire itself and possibly a break under the insulation as the cable goes brittle and crystallises from repeated overheating. When this cable is giving trouble, it is best to replace the whole cable back to the battery.
    Dec 2008
    Dec 2008
    Turned out the alternator had died, not just the regulator. It also killed the battery because it wouldn't hold a charge after that.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You need to take the flat battery down to an auto electrician for a special charge. Once the battery has been fully discharged it won't charge up just by using the alternator.
  1. Troubles with my VK
    By Dazza_Bo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2010, 04:02 PM
  2. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  3. Alternator Troubles?
    By tigers in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-03-2008, 06:30 PM
  4. Car Troubles
    By theused084 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2006, 06:35 PM
  5. sub box troubles HELP please
    By mistervr94v6 in forum Car Audio
    Last Post: 04-09-2005, 06:56 PM
