Results 1 to 14 of 14
Thread: how to polish engine to near mirror finish????
    vr wagon
    Aug 2010
    vic
    Question how to polish engine to near mirror finish????
    hi there, i have seen a few vr commodores with near mirror finish alloy components on their motor... any suggestions on how to get this finish out of my motor? cheers...
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    lotsa elbow power start with course grit finish at the end with steel wool
    EH Holden, VS Ute
    Nov 2008
    what kind of money do you want to spend on equipment?
    if you buy a good buffer, and some good lambs wool pads and some good gritty metal polish its pretty easy to do... thats the cheepest option
    or you could spend 3-4 hundred on a good strong bentch grinder and get a few polishing mops and do it that way... each will give the same result with enough time put in...
    either way you want to go... let us know and ill give more detailed description on how to go about it.
    cheers, Ray.
    vr wagon
    Aug 2010
    vic
    want to spend little as possible.. dont mind doing the hard yards by hand... prob go with buffer, hands and the metal polish... on a tight budget as saving for another car and fixing up other stuff on the car at the same time.... thanks mate..
    EH Holden, VS Ute
    Nov 2008
    i have never taken alloy to bright shine by hand, i wouldn't think it would be fun or easy...
    you best bet would be wet and dry... depending on how bad the alloy is your starting with you should start at something like 320grit and don't skip and grade right up to 1000...
    then get a small rubber disc backing pad you can put in your drill chuck and a wool pab to go with it. and hit it with that.
    i did these with bench grinder and polishing mops...
    Attached Thumbnails Attached Thumbnails how to polish engine to near mirror finish????-caliper-5.jpg   how to polish engine to near mirror finish????-caliper-2.jpg
    RichoKidd's Avatar
    RichoKidd is offline Obese Commodores
    VT 3.6 2000 Executive
    May 2010
    Perth, WA
    EH Holden, VS Ute
    Nov 2008
    acid won't polish, only clean...
    for something to be polsihed it makes the surface flat... so flat it reflects most light...
    simple acid or deoxidiser will only ever clean...
    VS II 5 ltr Berlina Wagon
    Apr 2004
    As godatfourdigital said, wet rub from course through to fine (2,000), then I used good old "brasso" and reflections metal polish paste on an electric drill fiited with a felt pad
    Mmmmm V8
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Check out this thread.
    be sure to comment. like any car enthusiast they like feedback on their hardwork
    Polishing the plenum on your ecotec
    vp wagger
    May 2008
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by vsv8berlinawag View Post
    Holly crap that must have taken ages to do and not to mention how much up keep to keep it that clean!
    Apr 2004
    It took quite a few weekends and many many Coopers Sparkling Ales ! but to keeping it polished up isn't to hard. All I do is give it a quick wipe over with Reflections metal polish 3 to 4 times a year though when I high pressure wash the engine you have to wipe it down asap before the water dries else it leave drip marks which take a bit more polish/effort to get out.
    Mmmmm V8
    vr wagon
    Aug 2010
    vic
    thats the look i want, bloody awsome... going to do anything i can thats polishable... starting with the intake manifold this weekend.. i know its only a 3.8l but hey make the best of what your given i say
  1. Bracket Finish
    By jpb308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2010, 09:44 PM
  2. Gloss Finish
    By 98VTExec in forum General
    Last Post: 07-12-2009, 03:54 PM
  3. Removing Synthetic Polish needed for non Synthetic Polish?
    By Chirpstr in forum Car Care Products
    Last Post: 30-07-2009, 08:20 PM
  4. Nu Finish??
    By AngryVN in forum General
    Last Post: 09-10-2007, 11:56 PM
  5. new mirror glass on external electric mirror
    By atberry in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2007, 08:01 AM
