Results 1 to 7 of 7
Thread: Vs ute speedo stopped working help!
    2003 VY SS Ute M6 2005 WRX STI
    Nov 2010
    Default Vs ute speedo stopped working help!
    Hi Folks, today ive noticed my speedo has stopped racking up the ks, the needle still works fine
    but will not clock up the ks now. Does anyone know what causes this and how to fix it? cheers!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    missing tooth on the small speedo gear. Very common to ping a tooth and they are about $20 to buy a replacement.
    and 3 Dangerous non ABS VN's
    Nov 2010
    Cheers, how is this removed and where is it located? pulling out the speedo?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    yeah, replacement cog.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    vs commodore
    Oct 2009
    Tamworth NSW
    Nov 2010
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Here is a link to a great "How-to" by Kopper69 which will show you just about everything you need to know....plus pictures!!!....when you do this job just be very careful when you pull the speedo apart and take note of what does where.
    Broken Odometer
    Also is a link for a cog delivered for $10 ODOMETER COG SPEEDO GEAR SUIT HOLDEN COMMODORE VN - VS (eBay item 180584820184 end time 08-Dec-10 17:06:50 AEDST) : Cars, Bikes, Boats
  1. My Speedo Stopped working
    By Conwaysinc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2010, 02:39 PM
  2. Speedo stopped working on Manual 3.8 VN
    By bjj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 06:52 PM
  3. VN speedo stopped working.
    By VN_SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2007, 12:32 AM
  4. Speedo stopped working!
    By jay_hman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2007, 11:46 PM
  5. Stopped Speedo
    By 4PLAYN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-09-2006, 07:16 PM
