Results 1 to 6 of 6
Thread: air intake problems
    wb panelvan
    Sep 2010
    nambucca heads
    Default air intake problems
    does anyone know what would cause back firing out of the air intake on a vs commodore and it not being able to rev? my engine idles rough and when i try to rev it, it just stalls? mayb fuel or air sensors? just put an after market out of tank fuel pump in, just wondering if maybe its not giving enough pressure? what pressure does the stock vs pump put out?
    cheers guys
    VS SS
    Nov 2010
    sydney
    wb panelvan
    Sep 2010
    nambucca heads
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    I'd be first checking the coilpacks & DFI module. If you have a mate with a VS swap the whole DFI moduel with the coilpacks on it and try that. Only takes a few minutes to swap.
    wb panelvan
    Sep 2010
    nambucca heads
    it is getting spark tho, held one of the plugs near the block and got a nice blue arch. but could the coil packs\DFI module still be a bit faulty or something?
    Sep 2005
    Quote Originally Posted by v6 panelvan View Post
    Its pretty common that the coilpacks crack and leak spark. Also the DFI modules go too. Also check the connection on the DFI module Ive had a few that have some corrosion in the connector.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. Vn Intake
    By sean lawrence in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2004, 09:08 AM
