Results 1 to 4 of 4
Thread: Tapping noise from motor of vr wagon
    VR WAGON
    Nov 2010
    Gold Coast, QLD
    Default Tapping noise from motor of vr wagon
    Hey guys I just can't win with this car lol i don't think anything else could possibly go wrong after this here's the issue...
    My exhaust is leaking from the flanges after the o2 sensor only slightly however the cars engine light comes on at around 1500 rpm only when there is no load on the engine as in, in between gear changes or under very light throttle. There is also a loud tapping sound that comes from the motor around the same rpm. I have checked the fault codes which have told me there's a leak in the exhaust and the car is running lean. My question is can a leaking manifold gasket cause this Loud tapping sound and possibly be sucking air into the exhaust causing it to give me a lean fault code? Also the noise gets louder as the revs go up but only on very minimal throttle the noise goes away if you
    Put your foot down and put the motor under load the motor also surges and idles quite rough it has a stage 3 crow cam in it but I wouldn't think it would cause any of the above issues? Any ideas?
    vs commodore
    Oct 2009
    Tamworth NSW
    An exhaust leak near the engine,or exhaust manifold leak can sometimes sound like theres a tapping sound coming from the engine..
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    The exhaust leak will definatly give a o2 sensor a faulty reading making the engine run rich, and the noise could be anything from the exhaust, lifter, cam and bottom end, but I'd start with the cheap one and fix the exhaust and work your way from there.
  1. VT Commodore Has a tapping noise
    By Jodamis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2010, 12:25 PM
  2. tapping noise
    By mardysholden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-01-2010, 10:52 AM
  3. Tapping Noise
    By Bloka in forum General
    Last Post: 24-07-2006, 01:31 PM
  4. Tapping from alloytec 190 motor
    By Walks_SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-05-2006, 03:03 PM
  5. Loud Tapping Noise
    By nelly77au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 01:44 PM
