Results 1 to 6 of 6
Thread: VX too VS connecting rods
    VS Spac 5 speed
    Nov 2010
    perth
    Default VX too VS connecting rods
    hey guys just wondering if i pull out a connecting rod out of a VX will it fit into my VS seeing as one of mine is buggered.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Yes they're interchangable as physically, all dimensions are the same between them. I would recommend weighing the rods though on an accurate scale just to make sure they're the same weight (they should be) to make sure you keep it all in balance. Don't mix your big end bearings though.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VS Spac 5 speed
    Nov 2010
    perth
    Cheer for the reply seeing as the con rods fit does that mean the crankshaft would be a straight swap and fit aswell?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Why not just change the whole bottom end?
    VS Spac 5 speed
    Nov 2010
    perth
    i might be i know one of the con rods is stuffed cause it spun a brand new big end in under 15 minutes of running time. So im either buying a new con rod or pulling one out of a spare VX motor i have also i have too machine my crank so might aswsell just use the VS bottom end.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by S pac View Post
    Yes, all v6 cranks from vs to vy l36 (ecotec) and l67 (supercharged) are the same with no differences at all. You'll probably only have to go 0.020" under for the crank grind and linish
    PM Me For Details
  1. connecting rod removing
    By the executive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2009, 11:10 AM
  2. Connecting Rod Bolts
    By timgamble74 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2009, 01:15 PM
  3. Connecting a VAC gauge to 3.8
    By TapouT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-02-2009, 12:15 AM
  4. Connecting Fog Lights on a VT S
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2008, 06:41 PM
  5. Dis-connecting immobiliser
    By Just_Ice in forum Electrical Wiring / Questions
    Last Post: 19-02-2006, 06:41 AM
