Results 1 to 4 of 4
Thread: I Didnt Expect this to just fall out into my hands
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Default I Didnt Expect this to just fall out into my hands
    Started to replace the front and back Radius Rod Bushes in the VS.
    Got everything apart no problems. Until I lowered the Control arm and the Inner Bush just fell out into my hand.
    Not sure it was meant to do that Arent they meant to be pressed out?
    I will now have to Replace them too
    I just cant wait to get to driving it again.
    Attached Thumbnails Attached Thumbnails I Didnt Expect this to just fall out into my hands-dscn2192.jpg
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Dayum, thats like winning lotto, BUT, does the bush that fell out have the metal shell on it ? If not then the shell is still in the control arm and needs to be smashed outta there before you can fit a new bush. Once you get the shell out you can fit a Urethane bussh in there at home cos they don't use a shell. A new steel shelled Rubber bush is much more difficult to fit as it needs a press like you said.
    vp wagger
    May 2008
    hmm the only thing i can think of is the last person to put them in tightened the bolt thru it before setting on the ground and the rubber has fought the shell for how ever long it been there ??!!!!!
    May 2010
    All fixed up now.
    Got Pedders to press in new Bushes
    Drives 1000 times better.
    highly recommended to do.
  1. fall out new vegas
    By Garth in forum The LAN Lounge
    Last Post: 17-11-2010, 11:30 AM
  2. power window regulators fall off
    By jeepster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2010, 07:24 PM
  3. why not to fall asleep at a party
    By Amped in forum Jokes/Humour
    Last Post: 24-08-2009, 10:09 PM
  4. Starter about to fall out
    By nsladden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-10-2007, 07:45 PM
  5. The Fall Of George W Bush
    By Jesk in forum Jokes/Humour
    Last Post: 11-10-2005, 10:50 PM
