Hi guys,I've attached a pic of my speedo cluster.is this what is meant to be in a 2000 vs ute.
I've getting conflicting reports as to what configuration is correct.
Thanks in advance
That looks right. What conflicting information are you getting?
What is the part number on the lens.
It should have a 2 letter prefix starting with S.
and 3 Dangerous non ABS VN's
was told that the vs had fuel on 1 side and temp on the other,no tacho.
Your thinking about the option level of the dash.In the VS models,you could order a level 1 dash,which had no tacho,or a level 2 dash,which had the tacho,or level 3 dash, which had the tacho and LCD readout screens.You can swap the level 1 and 2 dashes straight over with no modification to the wiring needed. The level 3 dash needs extra wiring spliced into the cars existing wiring loom to work.
