Results 1 to 8 of 8
Thread: vs idling in drive not right
    05 vz ss
    Oct 2010
    brisbane
    Default vs idling in drive not right
    g day everyone if theres any one who could help me again that would be great i got a vs and its got a a rough idle but as soon as she gets pretty warm it isnt as bad also in between drive and neutral she almost stalls when at traffic lights . everything that everyone talks about on her i have gone threw so im lost what it is so if theres someone a shit load smarter than me that can help me that would be great also this only accured after having pacemaker extractors fitted cheers
    05 vz ss
    Oct 2010
    brisbane
    ive spent thousands on repairing would it could possably be please help me out guys
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I assume you have done the basics such as clean the IAC, check codes etc.
    I would look at cleaning under the DFI and the bracket to the cylinder head to ensure a good earth. Make sure there is enough zinc oxide grease under the DFI so the heat sink is effective.
    Maybe a earth wire was damaged when the exhaust was fitted?? Look for this also.
    Vt Commodore Exec Series II
    Jul 2010
    sunshine coast
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Have you checked the O2 sensors? After fitting extractors the coating on the inside of them contaminates the sensors and can cause a bad idle.
    Visit my Facebook page
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    The pacemakers also fit the o2 sensors slightly further away from the engine than then stock headers, so together with your better flow from the exhaust and further distance your o2's will be reading differently than when they were in the stock headers, so your idle may become slightly ruff as the MAF calibration will be out by 7% or so, your ecu through blms with your o2 sensors will correct for this over time but it still wont be perfect, a tune and MAF recalibration can smooth out the idle and power curves again, i have done this on a 2 vs's now and the idle has been much better, im not an experienced tuner though like others here.
    As above first things to check would be o2's which can also die after installing extractors as the internal coating wears off, IAC may also need cleaning and resetting.
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Also if it's only in drive it could be the tune on the memcal if it's not stock
  1. DRIVE BELT URGENT .where can iget a drive belt in brisbane sunday for vt lsi motor
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-06-2010, 03:24 PM
  2. Idling :(
    By ducatis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2010, 07:51 PM
  3. To all Member That Don't Drive A Commodore, What Do You Drive:
    By Evolution_Ends_Here in forum The Pub
    Last Post: 07-12-2008, 05:40 PM
  4. to drive or not to drive- shredded cable
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 05:16 PM
  5. Low Idling
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-12-2005, 02:03 PM
