Results 1 to 10 of 10
Thread: Vs steering rack NEED HELP ASAP!!!!!!
    vs commodore
    Nov 2009
    Default Vs steering rack NEED HELP ASAP!!!!!!
    Hey guys, got a slight problem with the steering rack on my car or should i say the lack of fluid in it.....it has dropped all the oil out of it on the drivers side it was coming out of the rack end boot (or bellow) just curious as to weather this is a common thing and there is a quick seal to replace or if i have to put a new rack in.....keeping in mind i am moving town in less then 24 hours and dont have the much money left over....so if u could get back to me as quickly as possible it would be great
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    not what you want on moving day. How far are you moving and how fast is the leak ? if its slow you could fill it up and drive to your new joint.
    The seal can be done but don't know how easy to do, I just got a reco rack and changed it over - sorts out all the leaks, moans, groans and perished bits in one go.
    vs commodore
    Nov 2009
    it leaks bad enough to leave an almost constant line of fluid when the car is idling forward. moving 300km's and dont have the money at present for a reco rack. anyone got any ideas?? i am actually a parts interpreter for a holden dealership so i know what i am doing when it comes to mechanical side of things
    greenacc's Avatar
    VE Berlina
    Jul 2008
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If the leak from the rack is really that bad, you really have no choice but to fit another rack.
    Best would be reco, cheapest would be second hand.
    If you drive it without fliud (apart from being dangerous) you will just damage other components such as the pump.
    Make sure it's not a split high pressure hose before you pull the rack out.
    vs commodore
    Sep 2010
    wyongah,nsw
    just put sum sikaflex on it and filll it up lol u need a new rack mate no quick way out of this one
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by rick_james View Post
    If that is the case, then why are you asking on a forum instead of just fixing it?
    Visit my Facebook page
    vs commodore
    Nov 2009
    cause i cant really afford a new rack and i wasnt sure if there was another way to fix it. thats why i am on here asking buddy
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    No you have no choice, if it can leave a line while idling its way past gone, seals are likely FUBAR. Get a reco one to save coin.
    Ronald Reagan (1986)
    Vr Executive 3.8
    Dec 2008
    Isn't there a stop leak additive that some people have got away with for a while? made by lucus I think?
    Otherwise a second hand rack from the wreckers is $30, might not be the best but might get you out of trouble
    edit: http://www.supercheapauto.com.au/onl...=10778#details
    But if the leak is really really bad go a second hand rack
  1. how can you tell what steering rack you have
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2010, 02:46 PM
  2. VN to VT steering rack
    By OZLEE555 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2010, 05:11 PM
  3. Swap variable speed steering rack for regular rack?
    By _R_J_K_ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2010, 08:06 PM
  4. Vn steering rack
    By woo121961 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-07-2009, 02:11 AM
  5. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
