Results 1 to 8 of 8
Thread: VR series 2 ute power windows
    VR Ute
    Nov 2010
    Ballarat
    Default VR series 2 ute power windows
    Hi, i have just installed power windows in my vr series 2 ute. I am having trouble getting power to the window switch. I have used a passenger switch which doesnt have the lock on it, i also have both plugs under the stereo for drivers & passenger switch's. Ive put a fuse in 5 on the fuse panel & it has a relay for the windows but no power to the switch.
    can anyone help with this problem?
    Cheers Dean
    vs commodore
    Oct 2009
    Tamworth NSW
    You might have to change the ute BCM (Body Control Module) to a low series BCM from a VR executive etc that has power windows fitted.(not berlina or calais which have medium or high series BCM's fitted).Im pretty sure the utes didnt have the right BCM to support central locking or power windows.You need to change the key fob as well.This is because the key fob and BCM are coded together for the immobiliser.If the wrong key fob is used,the BCM wont allow the car to start,so you have to have the same ignition key fob from ther car that the BCM comes from so they match.You just gotta swap the plastic fob over to your ignition key then.
    VR Ute
    Nov 2010
    Ballarat
    Quote Originally Posted by Brett_jjj View Post
    Thanks for your help much appreciated. Didnt want to go changing BCMs so i have brought a VP module,so i will see how this goes.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Your existing power window wiring you've found under the dash and to the doors etc. is controlled by the BCM. Using a VN/VP window control module bypasses the BCM and external relays. In short, the wiring is quite different. I've done many power window installs with this method. If you check out the 'how to' section of this forum there's one on how to install power windows. Somewhere towards the end of this I have uploaded some holden wiring diagrams for the VN/VP power window system for both front only and front and rear windows. If you use the VP module you'll have to chop and change some of the existing wiring.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Aug 2008
    NSW South Coast
    Also, when you say you've used a passenger switch without a lock on it do you mean you've used one of the long power window switches to suit front and rear windows? When doing front power windows only you use the small switches that are the same as the rear door switches. May also seem silly, but did you check there is a contact on both sides of fuse 5 and not the top only?
    PM Me For Details
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Quote Originally Posted by colecam View Post
    You will need the module wiring loom from l/h door plug to r/h door plug from the vp donor car for it to work...on a vp it has a separate loom for window/door locking...
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Aug 2008
    NSW South Coast
    Quote Originally Posted by markovr View Post
    Or you can just run your own wires too. From the module you'll need to run two wires to each door.
    PM Me For Details
    VR Ute
    Nov 2010
    Ballarat
    Alls good, i made my own loom & used the vp module with the passenger switch(without child lock).
    Had no problems & its working well, had both contacts on fuse 5 so used this for power.
    Thanks for the help.
  1. Installing VX power windows into VT series 2
    By HoldenFan09 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2010, 07:42 PM
  2. How to put power windows door on non-power windows car?
    By deXtrous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2010, 05:35 PM
  3. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  4. [SA] 95 VR series 2 Equipe, power windows etc $1950
    By gsxrdan in forum Vehicles For Sale
    Last Post: 13-05-2009, 02:33 PM
  5. 96 VS acclaim series 2 = Power windows??
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2006, 08:35 PM
