any body got any suggestions,when i push my clutch to the floor there is a strange creeking noise like it is grinding on something,my thought is something is dry no oil or grease or something it only happens when the pedal is just about to the floor,the clutch set up is hydrolic cable assisted the master system is bolted to side of gear box,there is no leaks of fluid around,the gearbox is t56 it is running behind the 215 stroker motor,![]()
Know nothing about your car but have been told to reply with " Bad Input Shaft Bearing" (whatever that is)
Life Sucks? Well cry me a river, put on a helmet, build a bridge and get the f**k over it.
Could be either a bad/dry pilot bearing (sits in the end of the crankshaft and the nose of the gearbox input shaft spins on it) or the thrust bearing dry. If the sound seems to be coming from the pedal it could just be a dry shaft/bearing at the top of the pedal (will be there with engine off) - spray with WD40.
