Results 1 to 6 of 6
Thread: Doing some work to my v6 vr tips???
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Doing some work to my v6 vr tips???
    Hey guys n gals I'm doing some upgrades to my acclaim... Dorsey I'm doin a 5 speed conversion...I'm doin roller rockers n valve springs,, shaving the heads 10 thou,, porting n polishing the heads, extractors a 100 cell hiflo cat, and 2 1/2 stainless system, now what I want to know is what cam would be best in your opines.. I don't want anything to crazy though.. I'll be gearing a 70mm tb and blue vt injectors which will be one a custom fuel rail with a rising rate regulator, being fed from a intank pump into a surge tank. My second question is what pumps would be best and how big of a surge tank and will blue vt injectors be big enough, I will be getting either a chip or after market ecu. Which would best? Any other tips welcome thanks in advance
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    talk to whoever your buying your Roller Rockers from and get a package, obviously you dont want high ratio RR with a cam.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Why not go to 3" tube for your exhaust?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Vr acclaim
    Jun 2010
    A 3inch is that practicual and no where has em in rockhampton gotta order em... I had a stainless system on vp and loved it....
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    a Walbro intank pump would be more than sufficient without the surge tank...or if you use the surge tank use the intank pump to fill it and use a Walbro or Bosch 044 external to pump from there but its a bit of overkill for what you plan...rising rate reg is ok though...you need to check if the VT bluetops will work with your memcal...from memory the standard blacktops are high impedance and the bluetops are low impedance or visa versa and will need the memcal recalibrated to suit and anyway you'll be changing the memcals from auto to manual so send off the manual one to get done before you do the exchange that way it will be there ready for when you do...
    Vr acclaim
    Jun 2010
    I'm planning a forced induction route now so the fuel side will be heaps lol just gotta look into a few more things
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. VR 1994 Indicator doesnt work (Hazard lights work)
    By rester in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 01:40 PM
  3. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  4. Doing up my vx any tips
    By sir_knockers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2009, 11:46 PM
  5. SWAP: My work for your work!
    By thisispete in forum Swap / Wanted to Buy / Trade
    Last Post: 20-11-2005, 06:55 PM
