Results 1 to 18 of 18
Thread: Quick Diff Question *VS SS LSD into VS V6*
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Default Quick Diff Question *VS SS LSD into VS V6*
    Hey everyone, just a quick question, wondering if this diff will be a straight swap -
    VS SS LSD. I imagine it would be ABS and IRS as well.
    Into to my car, VS Calais V6, open diff.
    Thanks!
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    anything that is irs so from VS to VT series 1 should be the same, anything newer will be the 3 bolt , all you need to make sure is that you buy a 4 bolt that is the only differnece
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    You have IRS, so just disconnect the CV joints and tailshaft, drop out your Open wheel unit and fit up the SS one. Both VS, Both IRS, both have ABS...should be completely fine. Maybe take it to a diff specialist and get them to service it at the same time? Always a good idea.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    So would I be correct in saying a VY SS diff wouldn't fit because it's 3 bolt not 4 bolt?
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Yes, you are correct. However, I do believe you can change the centers (i.e. dig out the LSD center and use that one)
    Both 28 spline so it should be a simple fit.
    Correct me if I am wrong
    1997 VS II - S
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    I think you can unbolt the diff bit its-self and not the whole assembly (arms etc) and that will fit from a vy ss. You're right about the centres though.
    VY SS
    May 2009
    if you want to put a 3 bolt diff in out of a vy just find your self a tail shaft with a 3 bolt end on it and use the back of it and front half of your existing tailshaft, $1000 Bucks fitted is a lil bit steep. they are piss easy to fit, there is 8 allen key bolts on each axle, 4 bolts that hold the diff mount rubbber in place then 4 17mm bolts that hold the diff to the cradle , it can be done in around 1.5 hours considering your exhaust doesnt get in the way
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Raptor Charged VX View Post
    My exhaust probably will get in it the way, it's not standard VS. Thanks for the info about the tailshaft, so just grab the end of the VY tailshaft too and it's all good?
    VY SS
    May 2009
    yeah they just split at the uni. if its a single system you will be fine . if its twin you will have to take it off
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Doesn't bother me as long as I can get it on at the end of the day, cheers.
    Not going with the $1k installed anymore, looking at a different one with only 78 000kms on it.
    VY SS
    May 2009
    i bought a 3.46 ratio lsd out of vz with 35.000 k for 450 bucks you should be able to find something cheap
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Yeah definitely. Thanks for your help!! How much do you think it would cost to get a vy diff installed ?
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Should do it your self mate , took me like 3ish hours on my first shot . theres a write up somewhere .
    But if you don't have the time i guess you would be looking around $500 to install ( you supply parts)
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    I work 6 days a week lol. Would love to give it a shot but somethings gotta fund it all haha
  16. #16
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    So it looks like i'll be getting a diff from a vy ss. 78,000kms. Can anyone explain the differences to me? Is it just the tail shaft? Will the abs sensors, etc work ok?
  17. #17
    Trayner's Avatar
    Aug 2008
    Will be the same shape and have all the abs,irs all the same , only differance is the 3 bolt for the vx s2 onwards , vt and lower have the 4 bolts
    Have a bit of a look at this thread you can see that this one has 3 blots about 3-4 pics down
    LINKY
  18. #18
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Trayner View Post
    LINKY
    Thanks for that info man, so is it the 3-4 bolt difference in the mounting points? tail shaft? Bit confused still lol
  1. Another quick diff question
    By Gunns VC in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-08-2010, 12:05 AM
  2. !!Quick diff question please help!!
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2010, 06:14 AM
  3. Quick diff question
    By jhawk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2009, 06:48 PM
  4. Quick diff question
    By jonathanvb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2009, 07:30 PM
  5. VP diff quick question!
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 11:00 PM
