when i first got my VS live axle it was standard height but when i put the pedders sports rider kit in the exhaust started knocking so just need to know how i fix this
Are all the rubbers not stretched? should be ok unless they didn't bend it right.
Installed backwards...
Has it got the stock exhaust still on it?
A couple of things to try are to replace the rubbers, but the VS has fairly solid rubbers on the front and these don't tend to stretch that much, but it is still possible. The rear rubbers are very prone to stretching, so replace them. The other way is to bend the two brackets on the sides of the front muffler down a bit, this will pull the exhaust up.
it has 2.5inch redback and no the rubbers are good
have you got a adjustable panhard rod with the kink to clear the exhaust?
Check your rubbers and 8 supports man, Mine had the same problem...until I changed everything and fiddled with it. Hey presto, no more knocking.
If the exhaust hits on something, chances are it is fitted incorrectly or something is broken/bent. Even being lowered, the exhaust should still clear the panhard rod.
Try undoing the clamp on the rear muffler and lift it up as high as it will go then do it up again.
same thing happened to my vr years ago, although that was after i chopped it and hadd it sitting on the bump stops lol... i put it down to the aftermarket exhuast being bent wrong, was ok at standard hight but when dumped it hit and rattled,, installing new rubbers didnt work for me, so i solved it dodgy by removing rubbers and zip tie-ing it up close to the floor pan, dodgy?, yes, but stoped the noise and wasnt a bad fix for when i was a young lad with no doe lol...
adjustable parnhead rod+1.
ive got superlows all round in my vs ute with rear insluators taken out with an adjsble parnhead rod and never had a problem
