Hi Guys.
I Have had the the Engine Mounts in the VR, But im still getting some vibration at idle. not the engine running rough as you can sit a glass of water on it.
Now how hard is it to replace the transmission mount ? Do i just use a jack to get the weight off the mount then just remove and replace ? Not real Sure atm.
cheers
put the car on ramps and yes use a trolley jack to take the weight... takes about half an hour to replace... less if your good with the tools lol
Well I got Ramps, Trolly Jack, All the tools and a garage creeper and very good with tools, well i can change a water pump in 30 mins so i like to think i am lol, Just i dont want a transmission to land on my head thats all lol
I also encountered such problem months ago and find a bit difficulty. But a buddy from other forums told me it's straight forward..you only need two floor jacks, rubber sealant, pieces of hard wood, pry bar and hammer..oh before i forgot there is a manual on how to replace a transmission mount. I just neglect it on the garage. I'll just upload it to this thread as soon as i got it back...
It requires removal of the rear crossmember as well so as to get to the rear mount. Allow a few hours and don't put the jack under the transmission pan.
Dissagree !!!
Fair enough mate you just get to know the tricks of trade when you work in that trade,
Interesting cause iv read a few things its just Put car on ramps, take the weight of the trans, then just undo 4 bolts then the mount comes out, think ill just run the car up on the ramps first and have a lookie first lol
