Results 1 to 9 of 9
Thread: vt brake upgrade front and rear
    peter1 is offline peter1
    vr series 2
    May 2010
    Default vt brake upgrade front and rear
    Vr v6 abs with vt front and rear brake with vs booster with vt master cyclinder the problem i am having is the brake pedal good but when driving the brake pedal is getting harder and biulding up pressure and it starts and then lock up the rear brakes unless once you slow the pressure drops.If not i have to release the pressure by undoing the brake bleeder nipples.
    vs commodore
    Oct 2009
    Tamworth NSW
    Sounds like a problem with the master cylinder not relieving the fluid pressure properly and its building up pressure and holding the rear brakes on.Id check out the booster pushrod etc and if its all ok,then get either another master cylinder or a rebuild kit for it.Also is the brake pedal returning fully to the pedal stop?If not check the pedal return spring,and is the ABS light showing at all.It might be an error in the ABS system.You can check the ABS system for error codes just like you can flash up the error codes for the ECU.You just bridge terminals 5 and 12 on the 16 pin ALDL diagnostic plug under the steering column to flash the ABS codes up on the ABS dashlight..The ALDL connector terminal numbers go from right to left,top to bottom,so terminal 1 is the first top right one.And terminal 16 is the last left bottom one.
    (I also remember reading somewhere that someone had trouble like you with the rear brakes holding pressure and they had done the VT conversion too on a VS.It ended up being something to do with the VS booster pushrod length or something along them lines.So might also be worth looking at if you dont find anything else wrong.Im pretty sure he also had a low spoongy pedal sometimes too)
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As above, the pushrod on the VS booster is too long for the VT master.
    I spaced my master away from the booster.
    Do not pull the pushrod out of the booster as the reaction disc inside the booster may drop out.
    vr series 2
    May 2010
    Hi thank you for your advice and help and my brake pedal goes back to normal and I'm going to try to putting spacer between the booster and master cylinder after i check my abs codes once i try this i'll let you know how it goes thanks for your help.
    VP Exec
    Jun 2005
    The ABS solenoids have one way valves in them that prevent fluid pressure from being trapped between the wheel cylinders and the solenoid. The only way the ABS can be involved is if one of those was blocked i.e. it will almost certainly be the length of the pushrod as above.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by Cheap6 View Post
    To add to this,
    If it was a blockage, no ABS code would be logged.
    edals's Avatar
    edals is online now Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Question, If you just simply put on VT/VX Brake callipers onto a Standard VR, Do you need to upgrade the brake master cylinder or will it still be fine even though your going from single pot to twin pots.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by edals View Post
    Depends on the bore size.
    Try a search as there is a very good chance all your questions have been answered.
    vr series 2
    May 2010
    thank you the problem was the pushrod once i put spacer all good thank you for all your help much appreciated.
  1. VS to VY front brake upgrade.....
    By hsvbiggy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2010, 11:18 AM
  2. Brake upgrade kit...front&rear or just front??
    By bigben379 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-12-2009, 04:37 PM
  3. Rear Brake Upgrade
    By OLD BOY BRI in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2009, 04:35 AM
  4. Rear Brake Upgrade
    By gd81 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2006, 09:30 PM
  5. vn rear brake upgrade
    By jazz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-07-2005, 02:33 PM
