Results 1 to 3 of 3
Thread: How to test Vr T5 Speed Sensor / Speedo on instrument cluster after manual conversion
    BE39ER's Avatar
    BE39ER is offline More Torque Less Traction
    94 VR Commodore Berlina just converted to manual
    Jun 2010
    Newcastle
    Default How to test Vr T5 Speed Sensor / Speedo on instrument cluster after manual conversion
    Hey guys, I recently converted my Vr auto to a T5 manual and cant get my speedo working. I purchased a Manual ECU with a performance chip and all the wiring and very detailed info and pics to get the speedo / reverse lights working. Ive hooked it all up and still no speedo. The colours of the wires coming off my speed sensor on the gearbox have faded very badly and I cant really tell what colours they were origionaly. I am not sure if there could be a problem with the speedo on the cluster (prolly not as it worked as an auto) or a problem with the speed sensor on the T5. Which brings me to my first question. Would anyone out there possibly have a pic of the sensor that clearly shows the colours of the wires coming out of the head of the sensor? And also, is there a way to individually test the speed sensor and the speedo on the cluster? I have a multimeter but not sure how to approach it. I was thinkin of rigging up the sensor to a battery, and wrapping a small peice of cloth around the spline and gently attatching it to a cordless drill and giving it a whirl. But as I said I am not sure ifI have the colous on the sensor mixed up and dont want to short anything out. I have a bald spot from scratching my head so much and I have rego at the end of January. Someone please throw me a bone Cheers guys
    VR Senator
    Nov 2010
    im pretty sure u can setup an OHM metre on the speedo terminals and spin it up with ur hands to see if the speedo drive is working ok, as for wiring, look for a wiring diagram and go from there :>
    VP Exec
    Jun 2005
    Yes:
    White/blue.......... Earth
    Pink/blue.............12 volt accessories
    Purple/white......to speedo side of ECU
    With the sensor disconnected from the car harness at the plug, battery voltage connected to the P/B wire and the W/B connected to earth on the sensor pigtail, a test light between battery voltage and the P/W wire should switch between on and off (earthed and not earthed) as the sensor is rotated - by hand will do.
  1. Vs Manual Conversion - Speed Sensor
    By Mafo81 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2010, 11:55 PM
  2. Speedo light in BT1 instrument cluster
    By MrWooFarkinHoo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 09:03 AM
  3. No High intensity on Speedo (instrument cluster)
    By Tom_1569 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2009, 01:39 PM
  4. Need some help!!!! abt speedo sensor on Vr (auto to manual conversion)
    By holdenrocks in forum Electrical Wiring / Questions
    Last Post: 29-03-2008, 08:20 AM
  5. Fs: White Instrument Cluster Face Place (Dash Speedo etc)
    By vy sammy in forum Parts And Other Items For Sale
    Last Post: 16-12-2005, 06:41 PM
Tags for this Thread
