Results 1 to 5 of 5
Thread: vs fan trouble
    vl sl
    Sep 2009
    Default vs fan trouble
    hey guys just need some help with my vs the fan doesnt want to work to keep it cool so ive replaced the thermostat, temp guage sensor, and coolent temp sensor and its still not turning on so would like some help cheers?
    vs commodore
    Oct 2009
    Tamworth NSW
    To test the cooling fan and its systems, just remove the ECU temp sensor wiring from the temp sensor.(Theres 2 temp sensors,one is for the temp gauge which has 1 single wire,the other for the ECU and has multiple wires).Then start the engine.After approximately 12 seconds the cooling fan should switch on to low speed.Then after a further 6 seconds,the fan should then switch to high speed.If the cooling fan does this,the cooling fan and its systems are all working ok.
    Dec 2009
    As above but if it does not switch on then you would need to check the fuse and check the relay(s) if they are OK then there are probably issues with the control electronics.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Welcome to the forum.
    I'd instal a simple over-ride switch that allows you to manually turn the fan on/off - this presumes the fan is working which the above tests will prove. Remember that it's quite normal for the fan not to switch on till the gauge is between 1/2 and 3/4....mine switches on at 3/4 and has never boiled in 7 years of ownership.
    Link to switch: How to fit thermo fan bypass switch
    vl sl
    Sep 2009
    thanks guys ill go see if tht works
  1. Air con trouble
    By Matt83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-01-2010, 01:01 PM
  2. cop trouble
    By xcopr in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-09-2009, 07:46 PM
  3. Sub Trouble
    By B.C in forum Car Audio
    Last Post: 30-08-2006, 09:09 PM
  4. Vn Trouble
    By Stewart1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2005, 08:21 PM
