Results 1 to 5 of 5
Thread: Hidden feature in speed alert
    VS Executive series 2
    Nov 2010
    Thumbs up Hidden feature in speed alert
    Hello Fellow Commodore enthusiests, This is my first post on this forum and I have a cool trick for people who drive VR/VS Commos with the speed alert feature. With ignition off, hold down the 2 up and down arrows on the speed alert, turn on ignition while holding them down and the speed alert becomes a digital speedo, only drawback is the orange light flashes really brightly.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I think its been mentioned a few times in older threads but still a cool little trick.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id like to know why some speed alert units will set to a permanent digital speedo and some will only set to digital speedo with the orange flashing light blinking, these ones also reset themselves back to the speed alert once the car is turned of and on again.Some will stay on the speedo with no flashing orange light and will stay on speedo permanently even if the car is turned off and on.It has nothing to do with the car model the unit comes from because Ive seen some VR ones will set permanent and some wont, and some VS ones will set permanent and some wont.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    This has been covered before but welcome to the forum quite an impressive first post
    if you hold down the 2 arrows and switch the ignition on, it turns on the speedo temporarely (sp)
    if you hold all 3 buttons down for 10-15sec, it will set it as a speedo permanently. now once done, it will only show the speedo after a delay (or after the engine is running), it will show 100 when ignition is on without the blinking light.
    vs commodore
    Oct 2009
    Tamworth NSW
    Not all the units will do this.Some just wont set permanently.
  1. trap speed feature
    By xcopr in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-05-2011, 06:29 PM
  2. Speed Alert
    By Kirbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2009, 12:23 PM
  3. VS Speed Alert
    By scottr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2007, 06:54 PM
  4. Vr Speed Alert
    By VT ADDICTED in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2006, 12:45 PM
  5. digital speed read out in VS with speed alert
    By vs0001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 06:09 AM
