Results 1 to 11 of 11
Thread: vs computer
    bluecar is offline Donating Member
    VS EXECUTIVE WAGON
    Jun 2005
    rural victoria
    Default vs computer
    Decided to to try another computer
    The one in it has BWPJ 16241628 on it.
    There is another one around (on ebay) and it has BSTK 16231448.
    Am bidding on the one with the right letters and numbers but was wondering if they are interchangeable.
    And if one is better than the other.
    The reason for trying another is had a fuel consumption enhancement program put on the existing one a few years ago. Recently it has started to miss going up a hill. Put your foot down and it comes good but I presume it is running a little lean.
    Decided it was an easy to try another computer as go to a holden dealer to get the computer reprogrammed.
    The enhancement program did work a bit on trips. But it seemed to use more fuel before operating temp was reached.
    Anybody know anything about this sort of thing?
    vs commodore
    Oct 2009
    Tamworth NSW
    The VS BSTK ECU memcal was replaced by the BTXP memcal for cold hesitation and pinging problems.As far as I know this is only the memcal which clips in inside the ECU, under the metal cover.Not the whole ECU itself.Ive actually had problems when trying to use a newer VS memcal in my VS which has the BSTK memcal fitted.When a newer memcal is fitted,the oxygen sensor readings just about stop altogether or are very low,but are fine with the BSTK memcal.It will also set error code 76 and 78 with the later memcals.I tune my own memcals,and have been trying to find out what the go is with this,but no one seems to know why it does it..Theres supposed to be an earthing problem with the VS V6 oxygen sensors,but Ive tried the earth fix and there is no difference in the readings at all,so I doubt its that .If your car came with a later memcal than the BSTK,dont go back to it,use the newer VS ones like BTXP or BWPJ.If your car came with the BSTK memcal,then you might have the same oxygen sensor trouble that Im having if you try to fit the newer memcal.Also Ive never had a cold hesitation or pinging from the BSTK memcal.
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Quote Originally Posted by Brett_jjj View Post
    Hey I have have a VS V6 in a Hilux with dual fuel & I seem to have some sort of problem with the oxygen sensors giving incorrect readings as well - Its always been bad on fuel since I got it. So I put it on LPG & it still used fuel on LPG - so I removed the LPG computer & tuned it manually & finally I got something out of it. I had mixtures checked on a wide band setup & its running 15.5 & if my sensors where reading right - it should be in the middle of the scale of the meter that I have - but they are not - they just read lean as. I replaced exhaust manifold gaskets - had the exhaust checked for leaks when I replaced a muffler recently. I have done the earth fix as well - they seem to operate quite well - I have a Carman scan tool & I can read waveforms & they are doing everything right.
    The only thing left is too replace them - but I cant understand why they need replacement if they are putting out a good waveform..
    I am running a dual map memcal & a 3.7 diff ratio - I am after someone to do a tune & allow for the diff ratio change if you or someone else could do it - I am happy to pay something in return. If you have any ideas I would appreciate some help.
    VS EXECUTIVE WAGON
    Jun 2005
    rural victoria
    Thanks for your detailed answer, Brett. Owe you one. I'll make sure I get a BWPJ.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    CKUL is the next memcal revision after BWPJ which mainly only had updates for the newer transmissions which changed a heap of settings and shift timing. Id just stick with your stock BWPJ tune, to check if it's stock pull the blue memcal chip out of the ecu and take the blue cap off, if it has a silver looking sticker on it with BWPJ then it should be stock tune. If you want a reburn there plenty of people like Dr bob, delcowizzid and myself that could reburn a stock chip again if you wanted.
    Have you checked your leads, plugs and coils, these can cause a miss.
    bpefi just checkout one of those jaycar kits to adjust the speed sensor, then use a gps or something with speed to adjust it right.
    VS EXECUTIVE WAGON
    Jun 2005
    rural victoria
    Quote Originally Posted by The1 View Post
    I suppose I should try a set of leads but when you put your foot down going up a hill and it becomes another car, my reckoning has been the diagnosis I've done. I suppose I should take it to the local holden garage. They are usually o'k. But I am impressed by the knowledge on this forum.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Fair enough, i guess if you have a multimeter check the leads and coil packs resistances to see for anything obvious or try a spare set if you have one.
    VS EXECUTIVE WAGON
    Jun 2005
    rural victoria
    It was a lead. (red face) Funny how it was only noticed under light load at about 90 km/h
    The new computer is around about the same for fuel consumption to. Interesting experience all round.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    yeh they can break down in all sorts of varying conditions, the only fuel consumption noticeable would be by running an older tune which has more spark advance, the new tunes they dulled down a heap, you can use a newer tune with changed advanced spark, would increase power slightly if you used 95/98ron with it. If you want to check what version memcals were made for your ECU/PCM and car checkout this program, Memcal ID
    VS EXECUTIVE WAGON
    Jun 2005
    rural victoria
    It was actually bluechip from this forum who did fuel consumption stuff. I think it was better on a long trip. Got 34.5 mpg with a loaded car on the Newell Hiway once. He had the computer kick in at a lower temp. I think it begins at 58 degrees on the regular tune. And was more tolerant of speed change sucking petrol up. I think it was worse until the temp got up and around town no different. I'll check out your link but I'm a bit of a slow learner on this stuff. I date back to having an FE, second hand as it was. (if you know what one of those was.)
    VS Super6 Utility 5 speed
    Aug 2005
    Cairns, Australia
    Sounds like the OP has an oxygen sensor circuit/operation fault. Exhaust backpressure test would be a good idea. Check for voltage drop between battery and body/engine. Try both with engine off, ignition on, lights on, blower fan and radio. Next test is from engine to body with engine running and all accessories mentioned turned on. (need a multimeter set to mV) anything more than 100mV and you have a problem. Anything over 300mV and you will almost certainly need new earth cables from battery (both). Have seen up to 3 volts power drop before and got 16v at engine and 13.5v there abouts at body.
    VN - VY V6 Kalmaker tuning.
  1. Resetting your computer and trip computer special functions (VT - VX)
    By Darren in forum Holden Commodore How-To's
    Last Post: 19-01-2011, 07:05 PM
  2. [QLD] Wanted : VL turbo auto computer / trans computer
    By Goon in forum Swap / Wanted to Buy / Trade
    Last Post: 03-03-2009, 07:55 AM
  3. vk efi computer is the computer just for motor
    By quick202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2007, 11:13 PM
  4. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
  5. 32x CD - Rom for computer - $10
    By s0sage in forum Parts And Other Items For Sale
    Last Post: 17-11-2005, 11:09 AM
