Results 1 to 2 of 2
Thread: What PSI should VS Statesman airbag suspension be pumped up to?
    VRCalaisVR is offline That's what she said
    1999 VSIII Statesman
    Sep 2009
    Default What PSI should VS Statesman airbag suspension be pumped up to?
    SO I have a series 3 VS statesman and I was pumping up my tyres the other day and I thought I should check what PSI the airbag suspension was at, it was at 19 PSI. SHould It be higher than this?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    It should be from Min 10 psi - Max 40 psi they are poly air bags from Pedders.
  1. airbag suspension
    By commod8 in forum General
    Last Post: 07-03-2011, 10:06 PM
  2. Airbag suspension
    By jonzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2010, 01:29 AM
  3. VE Airbag Suspension
    By kieran.87 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-02-2010, 09:25 PM
  4. Airbag suspension
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-01-2010, 07:06 PM
