Results 1 to 6 of 6
Thread: VS fuel cut
    1995 VS Executive
    Mar 2009
    Default VS fuel cut
    hey all been having issues with my vs daily drive its v6 auto
    its like the car is getting fuel surge when i corner hard to the right fuel warning comes on and car stalls instantly will not start straight away ..
    i have changed fuel and fuel filter and filled the tank right up and it happened to me again today
    also today i realised that when i am driving if i go full throttle the auto will not change gear and holds rpm at 4000 ...
    only when in gear if i put it in Neutral i can rev to red line i only noticed this today because i usually drive it like a nana due to it being my daily..
    only thing i can think of is maybe the pump is nakered
    its stock as a rock no mods 250XXXkms
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd try a fault code check and see what it says: Checking error codes VR/VS (Revised)
    Possibly it's the throttle position sensor not telling the PCM where the throttle is.
    Re the stalling - if it only happened when under 1/2 fuel then I'd say the fuel return hose busted in the tank but you say it still happened on a full tank??
    1995 VS Executive
    Mar 2009
    alright cheers its not urgent just was concerned about it ..
    and yes it happened today on full tank but only once ..
    i'll sus out the return line and see if i can reset the compture withou hooking it up to a hand controller thing .
    thanks heaps for your help mate
    1995 vs v8 ute
    Oct 2010
    hoppers crossing (victoria)
    same thing happens to my v8 i checked codes and yes lots of codes came up including throttle position sensor. so yeah worth doing the test.
    vs
    Nov 2010
    fishing point
    1995 vs v8 ute
    Oct 2010
    whats a mini coil? where is it located?
LinkBacks (?)
  1. 17-12-2011, 03:41 PM
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
