Results 1 to 8 of 8
Thread: Checking O2 sensors?
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Question Checking O2 sensors?
    How do you actually 'Check' the O2 sensors besides the diagnostic pins under the dash. My codes show that everything is fine but I don't trust the codes 100%. Can you tell by just pulling them out and looking at them?
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    monitor the voltage with a scantool or multimeter, unless they are physically damaged you cant tell by looking at them,
    best trust the codes
    Rob
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    Quote Originally Posted by Doctor Bob
    Rob
    goto a mechanic and pay 30 bux and get connected to a tech1 computer diagnostic thing, well worth it, i did the self diagnostic and came clear, but got tech1 connected, and oxygen sensor dead and base idle 200rpms out :S
    Mar 2005
    South Coast, NSW
    Question
    Quote Originally Posted by fitzy2005
    Fitzy2005, Who did the tech1 compter test for you? A local mechanic or ultratune or similar?
    t2te50 Guest
    If thge spark plugs are fouled excessively I say change the sensors and perform the recall. The two black wires going to the ecu, just snip them and earth them to the chassis. They had a chronic problem with the dry solder inside the ecu braking up causing the oxygen sensor to cycle incorrectly.
    VY S2 Berlina
    Jul 2005
    Quote Originally Posted by Scooter79
    a local holden wrecker :P but your local holden dealer and some mechanics do them as well, i think it costs a little more though
    VS Exec Series II
    Mar 2005
    Quote Originally Posted by t2te50
    What model/s was this on?
    Clacks
    I have a 'couple'
    Jan 2005
    Bris
    I found that plugging a scanner into mine did not give a 100% clear picture of what was going on. I got an error code saying 'rich exhaust' but the scanner was saying that it was running very lean and we were getting large voltage changes in gear, but slight ones in neutral.
    I got it hooked up to a proper sniffer to tell exactly what has happening, turns out that at idle it is alternating between lean & rich, but is normal when in gear - weird...
  1. Checking your Computer for Faults (VN - VP)
    By Darren in forum Holden Commodore How-To's
    Last Post: 02-03-2012, 11:33 PM
  2. Checking Fault Codes
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2009, 08:15 PM
  3. checking rep points/notes
    By Boonz in forum Site Feedback / Site Problems
    Last Post: 24-11-2006, 07:35 AM
  4. Checking Front End.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 01:39 AM
  5. ECU Fault Checking How?
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-09-2005, 10:03 PM
