Results 1 to 11 of 11
Thread: map sensor
    vr
    Apr 2010
    Default map sensor
    does anybody know were the map sensor is on a vr???
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Big black box sitting on the firewall near the intake pipe. Green plug.
    vr
    Apr 2010
    ok mate thanx i found it.do u know if there is a way to test it just to make sure thats the problem
    92 VP Series 2
    Jan 2009
    East Brisbane
    ok this is what i have been told in the past, dont presume i am correct cos i may not be lol, but try this-
    start your car up, then while the car is idling pull off the hose that connects to the bottom of the map sensor, the car will most likely start idling like shit and probably stall. if this happens you have a good map sensor but if the car doesnt really change much when you pull the hose off then your map sensor is ****ed. anyone disagree with this method ?????? good luck champ
    92 VP Series 2
    Jan 2009
    East Brisbane
    what are the symptoms of your problem mate? excessive fuel usage? no power? running like shit? stalling randomly?
    92 VP Series 2
    Jan 2009
    East Brisbane
    just saw your other thread about getting error code 33. by any chance have you removed your throttle body recently? if so, double check to make sure the hose from the map sensor is connected to the throttle body properly, if the hose isnt connected then this is likely to be your problem....... it connects to the back of the throttle body (you can just squeeze your hand in between the throttle body and the firewall) to connect it if its not , otherwise a new map sensor shouldnt be more than 20 bucks from a local wreckers (or something like $200 from genuine holden lol)
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by zskinner View Post
    If it was a loose vac hose wouldn't the code have been a vac leak ? Code was low voltage map sensor. Try cleaning the terminals with electrical cleaner before you buy a new one.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    TPS can throw up map sensor error code as well
    vr
    Apr 2010
    92 VP Series 2
    Jan 2009
    East Brisbane
    this is just something that came to mind thats happened to me in the past...... wouldnt explain the code 33 but could be why the car isnt starting. make sure the gear selector is in park or neutral lol, i had the car off the road for 2 days once cos it wouldnt start, before i realised it was in reverse for some reason lol
    veII
    Jun 2009
    that method should work zskinner, or you can kink the hose, instead of disconnecting, but i would think car would, start then stall if it was the problem, i would check
    (1) you can 'hear' the fuel pump for few seconds with key at 'on',
    (2) check for spark while cranking (remove 2 leads from coil pack, should see nice blue spark across the two while mate cranking engine)
    if both these tests are ok then look into computer and sensory stuff....
    or let me know more specifically, is it a problem all of a suddon or have you just done a motor swap or was having trouble starting then not at all or what?
  1. 02 sensor on vs ute
    By Grant_69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2010, 06:52 AM
  2. VH heat sensor and petrol sensor!
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2009, 10:58 PM
  3. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  4. 02 sensor
    By toughvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2005, 11:00 PM
  5. o/2 Sensor
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2005, 12:21 PM
